So if time is not a huge consideration, is there anything wrong with simply using the 30 amp adapter every day and charging into the clothes-dryer outlet when I get home every day? I drive about 200miles and she recharges in about 8 hours. Does it damage the battery to routinely not use a Tesla charger? I piggybacked a second 30 amp outlet (NEMA14-30) into garage from the laundry room - only rule is that I can't use both dryer and charger at same time. No biggie. Electrician wanted to use 50 amp (NEMA14-50) outlet and so I'd use this 3 slotted adapter instead of the dryer one, stating that the car would know the amperage available was only 30 and only draw that. Is this true also? (any advantage or disadvantage to using a 3 slotted outlet with only the 30 available amps?
