I am experiencing issues with my wall connector and/or charging my tesla at home. Electricity keeps going off
I have already replaced the outside breaker and the problems continues. I decided to charge my tesla 3 only overnight to prevent charge overload but it still happening specially if the AC is on. Help! Now is happenning more often. I even charge it on a lower amperage.
Who (exactly) installed your wall connector? Was it a licensed electrician, or an unlicensed electrician, or you? Your post reads like "You" installed it, since you say " "I have already replaced the outside breaker"
If the answer to "who installed the wall connector" is " I did", then STOP, turn off the wall connector, do not use it any longer, and get a licensed electrician out to do inspect the install and perform it properly.
I am just guessing here but I am guessing "you" installed it, and, also did not do any sort of load calculation to see what it should be set at, and are overloading your panel (especially since you state:
People normalize electricity, but if its not installed properly it can start a fire. Yours is obviously not installed properly in some manner. Get someone who is licensed to do the work to do it.
If I am guessing incorrectly, and you actually did have an electrician install this, and the "I have already replaced the breaker" is actually "the electrician already replaced the breaker", get them back out there pronto and dont use the wall connector to charge until they inspect it. I am fairly certain thats not the case, though, and that this install was by you.
