Can you provide a picture of the wiring to provide power to the meter? I am running 6 gauge wires to my nema 14-50, but dont want to run the large wires through this same meter, so how did you provide power to it?I have one of these on my 14-50 outlet, but it could work with HPWC too.
AC 80-260V LCD Display Digital Current Voltage Power Energy Watt Multimeter Ammeter Voltmeter
by bayite Link: http://a.co/a0v7f0G
It reads within +/- 3% of my TeslaFi charging logs.
Could I wire the smaller power from the energy monitor directly with each leg when its terminated into the 14-50, or would I need to randomly splice the 6 gauge wire to attach it?I dont have a pic, but there are some good illustrations on the Amazon listing. The meter only needs 18-22g wire works for display power and sensors. The 4 terminals on the back of the display would never fit anything larger than 13g. The magnet loop with 2 sensor wires (shown in blue) goes around either outlet hot wire (x or y). If you dont want to disconnect the existing outlet wire get an open/close sensor like shown. Otherwise get the cheaper closed loop magnet and thread the 6g hot wire though before it gets terminated to the outlet.
I measured the gen 1 UMC at around 1 watt - Is anyone metering their charger's kW usage?Has anyone recorded the power draw rate while the Tesla mobile connector is idle, plugged in, and not actively charging the car? It’s always warm, so I assume drawing something constantly.
Your screws on the breakers should be torqued to the specification for that breaker, not just as hard as you can goI just loosened the screws in the breaker box and slipped the low power wire in. This did make contact but it is possible that it will negatively impact the connection to the 50 amp circuit, so screw it down hard. I finally had to use a mirror to see what I was doing as it kept not going in next to the big wire. This gave me a meter in the breaker box, but I will probably move it to the outlet box, cut a hole in the sheetrock for it.
I saw somewhere a guy built an adapter that plugged into the 14-50 and provided an outlet for the charger but mounted the meter inline. That might be nice if I wanna see what the power I use is in many locations.
-Randy
I plan on using this to measure the charger: https://www.amazon.com/gp/product/B00XD8WZX6
Normally goes on the main house in, but likely throw one on the charger since I love data.
Personally, I am a fan of the LED one, has a bigger, easier to read display.
https://www.amazon.com/KETOTEK-Digital-Multimeter-Current-Voltmeter/dp/B0734SZVWL
-Randy
That is a pull-out style disconnect on the right, no fuses or breakers. I did it to be thorough and I figure if I’m standing there and notice something wrong, I can pretty quickly pull that disconnect. Definitely faster than I can get to the breaker inside the house.
Whole setup is 60a. 4awg thhn.
