Wall mount Tesla wall mount.
Discussion in 'Model S: Battery & Charging' started by rw86347, Nov 25, 2016.
  1. rw86347
    rw86347 Member
    denver, co
    I have a J1772 charger that I used to use for my Nissan Leaf. I will be using it to charge my Tesla as well. I was planning on leaving the J1772 to Tesla adapter always attached to my charger. However, that means I can't insert my handle into this nifty little wall organizer.
    Does anyone sell a tesla dummy female wall mount?
    What is the name of this plug?
  2. bmah
    bmah Moderator, Model S/X, California Forums
    Lafayette, CA, USA
    I'm not sure if this would work or not on the J1772-to-Tesla adapter...I'm guessing not but I haven't tried that particular combination of gadgets:
    Tesla — Cable Organizer
    You might end up needing to coil up the cable and just let the J1772 + adapter end hang loose?
    I'm not sure what the name of the plug is that goes into the Model S...I've only heard it referred to as "the Tesla plug" (which isn't even correct, because IIRC the Tesla Roadster uses a different connector from the S/X).
    Bruce.
  3. pslawing
    pslawing Member
    North Carolina
