I am interested in replacing my lights with HIDs.......I live in Irvine, Ca and wondering if anyone has experience with this and if they know a place where it can be done......also, any guesses at what it would cost......thanks in advance
I have 2020 LR Plus and dont like the LED headlights.....I see little line in the road form the lights.....I would like to have HIDS if possiblethe pre-facelift headlights are already HID Xenons, the post facelift are LEDs. What exactly are you trying to do?
yes...here I think I need a new headlamp assembly......did the replacement on my truck and did the wiring and ballasts with new bulbs.....here I need the new assembly and I can tap into main wiring harness to get switched power and mount ballast.....just need someone to tell me what light assembly I need and if there is a shop that can do it for me reasonablyyou want to retrofit the old one? i believe the wiring is different. its funny because some people with the old style want to "refresh" their car by installing the new one.
I would pay someone $1200 if they could do mine.....the Tacoma I did was easy bit for me the first time, took a little linger but it worked......hardest thing was mounting the rt side ballast.....had to figure our how to remove the stupid washer tank......but I agree, HIDs are much better the why I have now.....for some reason my wife's 2019 Model 3 lights are absolutely outstanding....I want something that goos in my Model SI just got done upgrading my daughters 2012 Ford Fusion from Halogen to HID, here is how I did it:
How to Retrofit 2010-2012 Fusion without opening lens - FordFusionClub.com : The #1 Ford Fusion Forum
Fairly easy, Had to remove the front bumper cover, and mode the Headlights to install the new bi-xenon projectors. They are freaking amazing compared to the stockers. I also updated the fogs with HID in 3000K for a nice yellow fog cutting light.. Also ford had the damn things pointed at the ground. I pulled the specs for fog align and headlight alignment, and no one has flashed me with the new setup and more importantly my daughter can now see at night on her 3 hour drive on country roads back to school.
My next project is to add bi-xenons to my FJ Cruiser -
2007-2014 Toyota FJ Cruiser
There is also a guy the does this custom for like $1200..
Fairly easy, had to remove the front bumper cover, and mode the headlights to install the new bi-xenon projectors. They are freaking amazing compared to the stockers. I also updated the fogs with HID in 3000K for a nice yellow fog cutting light.. Also Ford had the damn things pointed at the ground. I pulled the specs for fogs and aligned them and the headlights using a laser level, and no one has flashed me with the new setup and more importantly my daughter can now see at night on her 3 hour drive on country roads back to school. Also the high beams are now the bi-xenons plus the regular hi-beams... which is crazy bright and throws a nice clean beam using the Bi-Xenon: Morimoto EVOX-R 2.0 - HID Projectors - Components
Here is the SAE Specs for aiming - checked my Model 'S's and both the them were not aimed right either...
Point your fog lights and driving lights in the right direction.
My next project is to add bi-xenons to my 2007 Toyota FJ Cruiser
How to do the install on an FJ -Official HID Retrofit Thread
There are several options for custom work just make sure they use Morimoto Elite or better ballasts and 6000K bulbs with EVX-R 2.0 HID projectors. all in with labor and parts (you provide the original headlights to be retrofitted), should be around $1200. Also Morimoto Elite, just announced Laser headlight retrofits... which is what I may jump to if its reasonable.
https://www.sickhids.com
Services — Evil Headlights | Custom Retrofitting Service in Southern California
Services
Headlight Junkies
it is a 2020 Model S, delivered 30 Jan 2020What year is your car?
yes I know...I did that on the Tacoma....and I really want HIDs for the Model Shalogen to HID still use the same "shape" which is 1 bulb circle. Have you seen the LED lights on the refresh? its a collection of small LEDs (4 of them?) in a row that form to create a singular beam. This is not something that can easily be retrofitted with HIDs. You'd either have to recreate an enclosure to use 1 bulb or get 4 tiny HID bulbs with 4 ballast to fit in the 4 slots?
Replacing the entire headlight to the pre-refresh which still uses 1 bulb is going to be much easier
I did a whole lot of research on the project and Morimoto......the Morimoto has had a lot of talk about "bouncing" and noise from their ballasts.....Thr HIDs are just better and have more throw then the LEDs.....LEDs are also hotter than HIDs and that is why most have a fan....I just got done upgrading my daughters 2012 Ford Fusion from Halogen to HID, here is how I did it:
Services
Headlight Junkies
“Model 3 Headlight AdjustmentsAre the MS lights “aimable” at all? They appear fixed to me, in a larger assembly....
Pop the hood pull up the front plastic cover and grab and Allen wrench to adjust the lights, just like the second video shows and pretty much every car made.Question is for my Model S. It has no such "adjust headlights" option in the service menu.
AAAHHHH.. Fogs on the Tesla, I have not messed with those... I bet I could pull the wheel liner and the belly pan and take a look...Understood now the confusion.
Original topic was aiming the fog lights, not the headlights. While I haven't dug into the headlights at all, I assume exactly what you say.
The fog lights, on the other hand, I *have* seen--just had a ranger replace a defective one. I couldn't believe the amount of crap that had to come off for him to get to it (to include the entire frunk & front bumper assembly). The fog lamp & the side lamp and whatever that third signature lamp is called are all in a single assembly, screwed onto the bumper assembly. No adjustments that I could see (but I certainly could be wrong...).
