Vendor Want to remove the Model Y emblems?...Think again.
Discussion in 'Model Y' started by dougatconcours, Mar 26, 2020.
  1. odguy
    odguy Member
    Wisconsin
    Won't water get in through the holes?
  2. btd08
    btd08 Member
    Chicago
    Someone did it!!!
  3. awedio_femi
    awedio_femi Member
    Ventura County
    Amen to that!!
  4. mobilesuit818
    mobilesuit818 Member
    L to the [email protected]#[email protected] A
    If you technically wrap the Suntek PPF all over the rear hatchback (I usually get the rear bumper/trunk area done by default), then you could apply a small piece of color specific (teslas paint are usually hard to match vinyl wise) vinyl underneath first, not a professional but I'm sure there is a work around
  5. noshadow
    noshadow Member
    Berkeley, CA
    Couldn't you easily just bondo those two small holes and paint over it? That's what I did with a previous car and it looked great (a body shop did it, pretty quick and was no extra cost since they were fixing other things).
  6. mobilesuit818
    Its all preference, but I prefer to not have bondo.
  7. noshadow
    noshadow Member
    Berkeley, CA
    sure, but it’s
    1. Emblem
    2. Holes
    3. bondo and no holes
    Bondo looks just fine, especially for two tiny holes.
  8. arnis
    arnis Member
    Estonia
    Double sided tape does not let water pass through.
    Those two holes can be plugged with tiny plastic grommets that look almost flush AND are color matching to OEM paint.
    Business idea.
    It's actually a good idea to have those holes as it speeds up assembly a LOT.
  9. dougatconcours
    Torrance, CA
  10. dougatconcours
    Torrance, CA
    Ha, ha, ha.......how about just a bandaid?
  11. dougatconcours
    Torrance, CA
    Best of luck with that.
  12. IdaBish
    IdaBish Member
    Tucson, AZ/Santa Maria, CA
    Doug, can you put that one on my list too??!!!
  13. novox77
    novox77 1.21 Gigawatts
    NH, MA
  14. Electric Steve
    BRIDGEPORT, CT
    Is this for the new fusion-powered Performance model? Yes, it does change into a giant robot and try to conquer the planet, but its acceleration is amazing!
  15. ckessel
    ckessel Active Member
    Good lord, this is an utter cluster f*** of a failure by Tesla. My Model Y is in for a wrap and ceramic right now, the shop has found that the Y now requires a new emblem since you can't just debadge.
    The parts option from the phone tree sends you to a group that will not answer and the mail box is full. I literally have no way to order the replacement emblem from Tesla and I can't drive around with holes in the hood.
  16. champ052005
    champ052005 Member
    Chicago
    Quickest way is probably going to be to order online from somewhere. I used RPM Tesla.
    Side note...this might look awkward as hell but you could have the installer ppf over the holes until you get the emblems shipped to you.
  17. St☰v☰
    St☰v☰ Member
    SoCal/Texas
    I'm thinking that the holes are stamped in, no labor, and installing the badges (F/R) is probably a lot easier and quicker now, no alignment tool, just dab some adhesive and slap in on... next...
  18. St☰v☰
    St☰v☰ Member
    SoCal/Texas
    Amazon and other places sell them, probably ebay too.
  19. mrbulk
    mrbulk Member
    Las Vegas NV
    If the aftermarket comes out with illuminated Tesla emblem kits for the Y then at least the wire holes are already pre-drilled for you...:D
    • Funny x 2
  20. BobbyD1
    BobbyD1 Member
    SF Bay Area
    That is correct...
