WARNING against Michelin Cross Climate+ Tires
Discussion in 'Model X: Driving Dynamics' started by Lhshockey24, Aug 31, 2019.
  1. Lhshockey24
    Lhshockey24 Member
    Livermore, CA + Lake Tahoe
    The crossclimates are such a drastic tread pattern, that I have no doubt it contributed to that change in the efficiency.
  2. Scott Fairchild
    Melbourne fl
    I'd chose the Pirelli All Season with a proven mileage and performance record.
  3. mongo
    mongo Well-Known Member
    Michigan
    That is due to typical cars having a center differential that is not up the the task of a constant speed difference between the front and rear tires. Since the front and rear are completely decoupled on a Tesla, that is not a factor. Instead, you 'only' have the issues of ABS and traction control needing to deal with different wheel speeds.
  4. Key-Master
    Key-Master Member
    Los Angeles
    I know I'm resurrecting an old post, but I wanted to share my experience in a similar situation. I discovered that inside edge of my rear tires on my Model X were chewed up and my tire place was nice enough to give me 2 loaner rear tires (Falkens) until the CrossClimate SUVs came in. Fronts were still the OEM Continentials. Autopilot was not happy, pingponging back and forth in the lane. Driving manually was a little difficult as well, requiring much more concentration than normal driving. They settled in a little bit after ~200 miles but still not good.
    Replaced all 4 tires with CrossClimate SUVs and autopilot was fine immediately after installing.
  5. justdoit
    justdoit Member
    San Jose, CA
    @Key-Master How do you like the CrossClimate's so far with the X? Any noticeable range or noise hit? I'm considering them for our X.
  6. MrAliG
    MrAliG Member
    UK
    I have 4x Crossclimates on my Model X. I have the 20inch wheels.
    There are no weird handling issues. Frankly the original title on this thread is highly misleading. It is clearly due to mixing very different tyres on the car and not a problem with Crossclimates. Warning against mixing tyres would be better.
    The OEM tyres for me in Europe were Michelin Latitude Sports. It only snows rarely here, but I did not feel confident on the Michelins in snow. They would struggle with the slope on my driveway with just a few millimetres of snow.
    Despite not having acoustic foam, I find them quieter than the OEM tyres. This is mainly at town speeds, at motorway speeds, they seem similar.
    There may be an increase in electricity consumption, but I have not tracked it closely enough to confirm. Energy consumption on a Model X is so low compared to a similarly sized and performing ICE SUV that I wouldn't worry about it.
  7. Scott Fairchild
    Melbourne fl
    Just bought some NEXEN tire for the X. Amazing, quiet ride. Great handling. $167 for the front. $169 for the back.
    What a deal. Found out this tire company has been making tires since 1932. Will test them out on the race track soon.
  8. fr100
    fr100 Member
    Northern CA
    Thread on Nexen tires: Nexen tires?
    Currently about $127-$130 each on Amazon
  9. Scott Fairchild
    Melbourne fl
    $167/$169 balanced and installed.
  10. mohanman
    mohanman Member
    Michigan
    Anyone have any more updates on this thread about the best quietest tire all weather right now??
  11. HyperionMark
    HyperionMark Member
    Brookings, SD
    Love them on my 3. Would love to have them some day in the future on my X.
  12. mohanman
    mohanman Member
    Michigan
    Mark, which ones the Michelin?
  13. hpartsch
    hpartsch Member
    wa
    Might be possible. Cross climate 2 came out. Additional sizes coming out in February to include 245/45/19 (Model S). I'm thinking of getting them next fall.
  14. HyperionMark
    HyperionMark Member
    Brookings, SD
    Yep, CrossClimate+
  15. Silicon Desert
    Silicon Desert Active Member
    Sparks Nevada / GF 1
    Those are the tires I got for my MX. 10,000 miles on them new. Really like them.
  16. sramzan
    sramzan Member
    NY
    Finally thoughts on cross climate 2s vs the Pirellis?
    Just lost my two rear tires to lovely NYC nails in the bloody tread. Going to replace all 4 tires anyways so trying to find the best (most comfortable ride and quiet) tires
  17. Scott Fairchild
    Melbourne fl
    I've been very happy with the NEXENS Quiet and comfortable ride. Sticky too.
  18. gluz24
    gluz24 Member
    What is the speed rating on your Crossclimate? I only see 108H which is much lower then Conti’s 108Y for the front.
    QUOTE="MrAliG, post: 5101669, member: 50446"]I have 4x Crossclimates on my Model X. I have the 20inch wheels.
    There may be an increase in electricity consumption, but I have not tracked it closely enough to confirm. Energy consumption on a Model X is so low compared to a similarly sized and performing ICE SUV that I wouldn't worry about it.[/QUOTE]
  19. MrAliG
    MrAliG Member
    UK
    Sorry I just saw this
    I have Crossclimate SUVs. My car has 255/45W20 on the front. They are 105W rated versus 105Y rated for the original Latitude Sport 3 acoustics. That is an ample top speed rating of 168mph
    The rears are 275/45Y20 so the same 110Y rating as the OEM tyres.
    I checked the tyres and the Michelin website just in case.
  20. Scott Fairchild
    Melbourne fl
    Tire recall: Continental needs to check 94,000 tires for possible tread loss
    At least 203 tires are defective, the company said, but it needs to recall nearly 100,000 tires to be sure.
    The issue at hand is the possibility for partial or total tread loss resulting from potential sudden air loss or belt edge separation.
    This is exactly what happened to my Continental tire on my 2016 Model X at 70 mph. Rapid decompression. I was fortunate to battle steer it to a safe stop and wait several hours for a flatbed tow to Tesla. You might not be as lucky.
    As I have said before. "Continental is the most expensive cheap tire you can buy."
    Buyer Beware: Do you really want to risk your and your families' safety? I wouldn't trust these tires, even on my lawnmower.
