  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Warning: Car unable to charge, unplug & try again
Arrived at a supercharger yesterday & plugged in to charge. After about 25 minutes of charging, charging stops, I get a message saying that car unable to charge, unplug & try again. Went to the charge port & saw a red ring. I unplugged then plugged in again. Charging starts up like normal for about a minute & I get the same message again. I tried again & again with the same problem. I decided to move to a different stall & all is fine. Anyone here experienced this problem before?
Yes, it has happened to me. Nothing wrong with my car. I moved to another supercharger and got the job done.
Have had this problem fairly often at the Dublin supercharger. It's anything from being disconnected 5-10 min in, to "waiting for charging" to start.
A week or two ago, it connected and started charging and I was charging at the awesome rate of 1 mile an hour.
No fix, you just drive off and try again later. Never had these problems elsewhere.
Yes, I've had this happen as well, most recently I stopped with 20% at a SC on a major highway and 3 of 6 stalls were inop and others were in use. I ended up driving to another SC location off the highway about 25 miles and 1st one I plugged into started then failed a few moments later. Lucky for me one of the other 9 at that location worked flawlessly.
Tesla needs to add a report SC issue button to the map system. Supposedly they are all monitored for charging issues and reported automatically but when 3 of 6 fail that can be an issue if there weren't other options within range.
