LongRanger
Yes there is that of course, on such a new car I would want to know it has never had enough in from new not that it has lost any ... although a top-up would prove the same thing over time
No I'm not joking. Brakes are a consumable just like tyres and require the owner to inspect from time to time and maintain as necessary. Just waiting until a scheduled service or until a warning light comes on can lead to problems. You have to use your eyes and look at them and take remedial action if required.
Here is a good practice to seat the pads when new, or if you start to hear any noise like squeaking:
1) Find a nice open road without traffic (or speed cameras) and do this in decent weather vs during a rainy or foggy day with mist
2) Switch on low regen
3) Accelerate to 80-90 Kmh (50-60 Mph or so) and then apply firm and consistent braking down to 10 Kmh. Do not vary the pressure and be firm enough to start to generate some heat from the pads to the rotors.
4) Drive for 30 seconds at decent spead to cool slightly
5) repeat this process at least 5 times, I do it 6-8 times
6) VERY IMPORTANT: once this process is completed do not then park the car. Drive the car on the highway for 15 minutes or so to cool everything down. If you park right away you can risk having the heat transfer pad material in one spot to the rotors.
Your rotors and pads should now be in great shape with a perfect spread of pad material to the rotors. No noise, and excellent bite.
Ah yes! The old Italian brake tune up! ;-)
Low Creep or Dominic Cummings mode if you like’
I thought DC mode set navigate on autopilot, with Barnard Castle as the destination (only for an eyesight test, mind).
This isn't about wear, it's to do with lack of use.
Yes, brakes need to be used properly once in a while or they'll think they're not needed and go all crusty and useless.Sorry misread - so we need to be stamping on these anchors every now and then?
One thing I have noticed is the regen braking force in the S is less than that in the 3 and I have found I am using the brakes considerably more.
These days, i can't see any issues with any service centre or garage sending you photos of the condition of parts like these to demonstrate why they would need replacing. Otherwise, a simple explanation as to why they recommended replacement is the minimum.My Model X is due its MOT, so I took it in for a service and to get the yellow line fixed on the screen.
I asked what they do for service and they said they would just check the car over and see if anything was needed.
They told me they needed to do a brake strip and clean at £113. Fair enough, so I told them to do it.
Then they called back and said that they were recommending that all the brake pads and discs were changed at a cost of over £1000.
I said how could an EV with so few miles (18,000) need new pads and discs.
They said it was only a recomendation. I said fine, don't do it then. They said OK they would just put them back on..
I found it all somewhat strange. they didn't give any reason for recommending the brake replacement.
Yes, I asked why would a EV with regenerative braking need new brakes at such a low mileage. He just responded that it was only a recommendation and didn't have to be done.Did you ask them for a reason?
