Warning screen: "Tires too hot"
Discussion in 'Roadster: Technical' started by NigelM, May 31, 2014.
  1. NigelM
    NigelM Recovering Member
    Sarasota, FL
    This is new for me and I didn't find anything on a search. My wife was driving this morning, air temp is in the low 90s so not unusual, when she got a warning bing and the message "Tires too hot." She didn't note the error code but after tapping the screen she then got a warning to check the right front pressure (it's fine btw).
    i wasn't aware that there are even temp sensors in the wheels.....? Can anyone educate me?
  2. thefortunes
    thefortunes Member
    Wisconsin
    The Roadster has temp sensors integrated into the TPMS. It can be displayed via OVMS.
  3. djp
    djp Roadster 2.0 VIN939
    Toronto, Canada
    If you engage the parking brake and go into Info (i) and Tires it'll show you the pressure and temperature of each tire. It takes a few minutes of driving to pick up all the readings.
    This the first I've heard of an error for overheated tires. It could be a bad sensor. I've melted my tires on a track and the error never came up.
  4. NigelM
    Sarasota, FL
    I knew about the TPMS and how to see the pressures but never knew there were temp limits....wonder what the actual limit numbers are?
  5. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Do you have OVMS? It tells you the tire temperatures. I've never seen this error before though.
  6. jerry33
    Texas
    Tires too hot would generally mean not enough pressure, really bad alignment, or a combination. It could also happen if a brake caliper caused the pads to continually rub on the rotor.
  7. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    Well she needs to stop doing standing burn outs to start.
  8. NigelM
    Sarasota, FL
    Thanks for the reminders regarding seeing tire temps. Surprise, surprise...yesterday my car started showing a warning that the "TPMS Monitor Requires Service". Time to call the service center.
  9. Owner
    Owner Active Member
    San Francisco Bay Area
    #9 Owner, Jun 6, 2014
    oops...did not realize this was a Roadster warning....my comments were about the Model S (I scan new posts and used to have a Roadster).
    I got a brief warning the other day about tire pressure too high, but it went away after a few seconds. Are you sure it said "too hot" not "too high"?
    I had a flaky TPMS on one wheel for a long time, nothing to really worry about. Get it fixed eventually.
  10. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    I had that same error a few years ago - bad sensor.
    - - - Updated - - -
    Definitely was a "too hot" error.
