Warning to Autopilot users in Socal on the 5 FWY south bound in Burbank
GaboPaz
60
14
Granada Hills, California
Hi guys.
There is construction on the I5 in Burbank and today before the Verdugo off-ramp heading southbound my car jumped a lane without warning while on Autopilot (from the fast lane to the lane on the right). I believe the position of the sunlight reflecting off of the road in conjunction with the grooves of the freeway which aligned with the route the car took are the main culprits. It was still a very uncomfortable situation. Luckily I did look around me before the car veered off into the wrong lane. Not sure if the car would have done this if there was a car next to me on the next lane over.
The car also went over the left lane marker on the fast lane which was very scary.
Be careful on this section of the freeway. It has been under construction for months and this is not the first time the car acted strangely while autopilot is engaged.
Knightshade
11,150
14,457
NC
Video would be helpful- you should at least have dashcam vid... ideal would also be a video from inside the car showing the display and what state AP is in and what it was doing.
Tesla would be interested in seeing that too if you have it (or can replicate it)
Reactions: beachmiles
protoclown
13
Orange County, California
That would be enough for me to stop trying to use AP on that stretch of road. If there's anything tricky, like super narrow lanes or construction, I don't trust it.
There are also sections of freeway around LA that basically have no shoulder, so a lot of debris piles up and intrudes a bit into the fast lane. AP has come close to hitting stuff while I was driving there.
Reactions: goldengate
GaboPaz
60
14
Yes, I downloaded video a few minutes after the incident (after I remembered that my car had that feature). I'll look for it tonight and loaded on here.
Reactions: Knightshade
eslamotors
7
0
Los Angeles
I'm in the Burbank area frequently and I nowadays always turn off AP when approaching this area. My car has only successfully made that curve once out of many times.
Side note: On the opposite side of the freeway (5 northbound) around the Hollywood Way exit, TACC will randomly reduce speed to 35mph on the freeway (when other cars are going 70mph+). Likely due to GPS/maps issue?
megant113
71
68
So Cal Desert
Yep, I've seen the same in that area. My guess is that the construction has shifted traffic far enough to the right for the car to think you're on the off-ramp.
Pkmmte
Le meow
Sep 19, 2017
687
1,172
Los Angeles, California
Yeah, mine does that all the time in this area. It also tries to smash through the barriers in the closed exit if you have NoA enabled and it thinks it's still open.
Sometimes it even ignores the exit after that one even if NoA says it'll get out there. The exact opposite problem as the one above.
I pass through there so often that nowadays I just giggle at it every time it tries to kill me. :)
Apollo3
12
12
I never trust AP on that stretch of freeway! It’s not that bad anymore luckily. A few months ago there were half erased lane lines and barriers sticking out into the left lane. It’s gotten much better now but there are sections with sharp turns where there’s a faded line that goes straight and the car decides to follow that instead of the lane line. One day they’ll finish construction on that stretch of freeway... one day
boriszima
660
315
Los Angeles
My policy. Construction zone = AP Off
yes that. I drive that section almost on weekly basis and it’s one of the few local freeway sections where I won’t use AutoPilot. Lanes are not clearly marked, old markings are still there and no should. Basically, if construction I drive. Tesla is a bit too risky for that so far.
Az_Rael
5,602
8,749
Palmdale, CA
I have a hard time with that section and my meat brain, especially when the sun is low. Several times I have been through, and had a “oh, crap, these aren’t the lane lines” moment.
kalalp
New Member
May 18, 2019
3
0
San Joaquin Valley
Hi guys.
I don't think I would be exaggerating if I said that section of freeway has been under construction for at least ten years.
