  • The latest TMC Podcast (#17) is now available on YouTube and all major podcast networks. We covered EV Tax Credit 2.0, Model Y & 3 Gangbuster Sales, Low Model X Demand, and California FSD Drama.
Warranty Coverage? Front Left Safety Restraint System Fault (RCM_a027)
Others have posted about their many visits to the SC to get the Front left safety restraint system fault fixed. I, too, have experienced the same. It’s an error that won’t go away, even after I spent $300 to have SC replace my wiring harness.
Now the SC is saying they want $2100 to replace the seat. Trouble is that my M3 is over 4 years old, so that’s up to me to cover the cost….or is it? I found on Tesla.com that the Tesla Limited Warranty covers the Supplemental Restraint System (SRS) for 5 years or 60k mi.
Tesla service has mentioned nothing about this warranty covering my safety restraint fault. My car is 4.5 yrs old with 45k mi. Has anyone in TMC had luck in getting it covered under the SRS warranty?
stopcrazypp
12,415
8,282
Point them to that section in the warranty and see how they respond. Note people saying they have gotten it covered under that section won't necessarily help your case, as the SCs do not take prior cases as a precedent (even if you send them a copy of invoice).
From a quick google, I found a case there where the error occurred when the cable was not plugged in all the way.
Tesla Owners Club New York State - Front left safety restraint system fault - Contact Tesla Service (Repost from M3)
This site has other troubleshooting steps:
Moving seats all the way in both directions to see if it changes things when the seat is in different positions.
If seat ever got a spill, drying out the seat with a hair dryer or the seat heaters.
Understanding Tesla Message: Front Left Safety Restraint System Fault - enrg.io
Reactions: calidreamz808
Upvote 0
I have the same problem, front passenger safety restraint error. Out of warranty, they fixed a sensor under the seat a year ago. Now they want to charge me the $2100 to replace seat that won't even be available until July. They did not mention the supplemental restrain warranty. SC have admitted it's a safety issue but cannot explain why it is not a general recall. Shouldn't a safety issue trigger a federal recall given the frequency of the issue?
Upvote 0
Did you already refer Service to the warranty info you found online?
Yes, I tried a couple times with one Service Center to no avail. Because the tech wanted to replace the entire seat, they felt it wasn’t an item covered under SRS.
However, I then took it to
Thank you for the recommendations. I worked with a local Tesla guru/tech to try some options, which included the troubleshooting you mentioned. Unfortunately, no luck fixing it.
Upvote 0
I would think so. Some other car manufacturers provide a lifetime warranty particular safety-related components.
Upvote 0
If it comes to it, there are Model 3 seats online you can order for way cheaper than that.
That’s my backup option. I found a supplier here in Phoenix (Henry) who will get me a used seat in great condition.
Even that cost is several hundred $$. But certainly cheaper. My concern is: “what if they’re wrong?” What if I replace the seat and it’s still an issue. Heck, SC already replace the wiring harness and that didn’t fix it.
Upvote 0
afadeev
1,089
1,286
NYC
How quant of them.
All those "old" car companies care about their reputation and customer satisfaction - that's so yesterday.
Tesla is the future.
We all saved money by bypassing the dealership model mark-up, so now we get to see the other side of the coin of dealing directly with a capricious auto OEM without an intermediary. If they refuse to honor a warranty claim, it's final. No appeal, no dispute resolution.
Except a lawyer and a lawsuit.
Cheers!
Upvote 0
KenC
4,421
4,133
Maine
I got that alert. It occurs when my seat moves from its driver setting to Easy Exit, which I have set to move up. It clearly was related to the seat connector being stretched as the seat moved. I figured some zip tie was too tight, and needed to be snipped. I let the Service Center do it, but I would have tried it myself if I was out of warranty. Good to know there's a SRS warranty that's longer.
Upvote 0
How quant of them.
Cheers!
We should write to NTSB. It's a known problem to them, right on the repair invoice. The old style harness has this problem.
Reactions: T3SLAROD
Upvote 0
To give you all an update on this….I ended up finding an SC that covered the seat replacement under the SRS warranty. The SC service rep didn’t know that SRS warranty existed. I had to show him on Tesla’s website. He then spoke to his manager and they covered it.
So, I got a new driver’s side seat. But the saga continued because the error persisted. I returned it to the SC and they replaced the controller. That did it! Problem solved at no $$$ cost to me.
Upvote 0
stopcrazypp
12,415
8,282
So the same trick of finding a different "dealer" works for Tesla too.
Upvote 0
