Was the Model 3 Trunk Opening Changed at All?
Discussion in 'Model 3' started by mdevp, Oct 29, 2016.
Tags:
  1. Zaphod
    Zaphod Galaxy President (former)
    Austin, TX
    I'm sure any of the items you mention will be no problem with the opening size.
    • Like x 4
  2. stopcrazypp
    stopcrazypp Well-Known Member
    I had the same thought. I think the second split is just to mirror the charge port door as you noted. If you look at the protoypes, the charge port door had the same seam:
  3. McHoffa
    McHoffa EV.network
    Canton, NC
    I think this IS one of the original prototypes with AP2 cameras added. There is nothing else different from this car and the first prototypes we saw a year ago.
    I think he's fooling us. We get down about this being final and then they roll out the real finished product.
  4. alseTrick
    alseTrick Active Member
    Florida, USA
    Ditto. No way any of that won't fit.
  5. bro1999
    bro1999 Active Member
    Maryland
    Hey, if the relatively small trunk opening of the Model 3 doesn't let you fit in bigger items, you guys can pick up a used "beater" Bolt next year to handle such utility runs to fit in bulky items. Since most 3 reservation holders won't get their 3 until probably 2nd half of next year at the earliest anyways, there should be some used '17 Bolts available by then. 56.6 cubic feet of space with the rear seats down. ;)
  6. Weezer Fan
    Weezer Fan Member
    Denver, CO
    Actually, (besides being an EV), the usable space in the back of this vehicle is the only thing I like about it. It's tall, but not very horizontally deep.
  7. Garlan Garner
    Garlan Garner Banned
    Chicagoland
    Looks like they inserted the charge port.
  8. McHoffa
    McHoffa EV.network
    Canton, NC
    If the new seam in the taillight is for a new opening, this is how it would look
    • Informative x 5
    • Helpful x 3
    • Funny x 3
  9. Zaphod
    Austin, TX
    No way it will be like that. That is an engineering and manufacturing nightmare. Plus, it doesn't address the primary concern of the opening, which was the height, not the width.
    The new seam on the passenger side is just a design element to mimic the charge port opening on the driverside. Or there could possibly be charge ports on either side, but I am almost certain it has nothing to do with the trunk opening.
    • Like x 5
  10. North75
    North75 Member
    MA
    Yes.. Nice render though. It shows just how ridiculous that idea would have been.
    • Like x 6
  11. BluestarE3
    BluestarE3 Active Member
    Norcal
    I'm pretty sure that's exactly the point @McHoffa was making with that render.
    EDIT: @North75 beat me to it!
  12. Garlan Garner
    Chicagoland
    I like it.
    • Funny x 2
  13. AnxietyRanger
    AnxietyRanger Well-Known Member
    EU
    Good point about the charge port. It certainly seems possible what we think is a part of the trunk opening, is actually just a charge port opening.
    However, it still seems possible extending towards the sides and making the interior parts of the trunk corners a little smaller perhaps downwards as well could be in the books. Here is a less extreme mock-up of @McHoffa 's inspired thinking...
    Not pictured here, but they might also shorten the big rear window a bit to add a little height as well?
  14. quartzav
    quartzav Member
    I agree shortened rear big window is the most likely way to increase the opening height. I just can't see that from the sighting pictures though.
  15. S3XY
    S3XY Active Member
    Buffalo, NY
    #35 S3XY, Apr 8, 2017
    I wonder if they just found a way to narrow the inner lower sill to make the opening slightly bigger without changing the exterior at all. It wouldn't make a huge difference but would technically make Elon's statement that the small opening was "fixed". One thing I just realized is that the trunk interior will be larger than most sedans just from the fact that the trunk hinge/arm doesn't retract into the trunk when it's closed.
  16. Gen3Joe
    Gen3Joe Member
    United States
    #36 Gen3Joe, Apr 8, 2017
    They definitely DID change the rear of the car presumably to accommodate more trunk space. It went from "damn that looks hot" to "can I trade this mini X in for my mini S". The proportions are all off now and the car is left looking bloated and very unsporty.
    See the direct side shot of the rear end from here:
    TESLARATI.com
    ...and compare it to the one from here:
    Tesla Model 3: Will it Be a Good Family Car? - Motor Trend
    Edit: maybe definitely did is a little too strong. I'm hoping beyond hope that this is some trick of camera distortion that is there in every new spy shot of the car. It's not looking good for this hope though given what I'm seeing.
  17. NeverFollow
    NeverFollow Active Member
    I agree, shortening a little bit the rear window would also allow to
    wider the opening and ease integrating all the rear lights to the hatch.
    See comparison with Audi Q5/Q7.
  18. slipnslider
    slipnslider Member
    los angeles, ca
    How am I supposed to fit a medium stroller into that trunk?
    I could do it with the volt hatchback, but I guess Musk doesn't think people should have babies.
    Tiny trunk opening = no strollers = no sales to young families.
    That combined with the needlessly radical dashboard are pushing me towards cancellation.
    • Disagree x 2
  19. pkulak
    pkulak Member
    Portland, OR
    Visibility, Aerodynamics, Cargo
    Pick two. I'm fine with visibility and aero. And if you can afford a car like this, you can afford a decent stroller that folds nicely.
    Just some examples:
    2,3 = S,X
    1,2 = 3
    1,3 = minivan
  20. garsh
    garsh Re Member
    Pittsburgh
    By sliding it in. It's not that small of an opening.
    People who can't figure out how to put a stroller into a trunk probably shouldn't have babies. :D
    • Funny x 4
