Washer fluid / wiper performance question
Discussion in 'Model S: User Interface' started by eco5280, Feb 25, 2015.
  1. eco5280
    eco5280 Member
    Country
    My 85D is a week old and has lived exclusively in snow so far. So I've been dealing with a constantly dirty windshield and constant use of the washer fluid. My problem is - the top half of the windshield, at least on the driver's side, isn't getting clean. The spray isn't going higher than that. How do yours perform? Do I have a defective nozzle?
  2. Kalud
    Kalud Active Member
    Montreal, QC
    The nozzles are adjustable, I "tuned" mine a while ago. You can do it with a small pin or ask you service center. The end of the nozzle can rotate in any direction, you can actually get them to spray over the car...
  3. eco5280
    eco5280 Member
    Country
    Thanks, Kalud. That's great news. I was worried they were just a bit lackluster but it sounds like a quick and easy fix!
    I still miss my mom's 1994 Cadillac Deville's wipers. The washer fluid was sprayed from the wiper arm itself so it just plowed through any snow, dirt, grime, etc and left the windshield so clean, in one swipe. I don't know why they all aren't like that. It was a thing of beauty.
  4. JPP
    JPP Active Member
    SF Bay Area, CA
    ...a thing of beauty until the small flexible rubber hose failed/froze/cracked.....
  5. eco5280
    eco5280 Member
    Country
    Maybe, I had the car in Colorado (dry and cold, both not great for rubber hoses) and had the car until 2006 with no issues at all. And the part was probably cheap if/when it does fail.
  6. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I am not happy with the washer jets. My Acura mists the entire screen, making cleaning both less prone to scratching the glass and it cleans pretty much perfectly after 1 wipe. I do have the same problem hat the Op mentioned with the upper part of the screen on my MS not getting clean when I am moving. If I am stopped, I seem to be able to get a much better wipe. I think it needs a redesign. But thanks for the suggestion of repointing the jets. I will give it a try. I just wish I could figure a way for it spray more, rather than simply shoot a blob of fluid into essentially one small place from each jet. I am fortunate in that I do not live in a snowy climate with sand and salt. Did that for way too long!
  7. eco5280
    eco5280 Member
    Country
    Are there aftermarket washer spray nozzles? <Googles frantically> Found this thread. Apparently GM stuck with this design, a poster mentions it on his truck. So jealous, honestly, you don't know what you're missing. It's like heaven in a spray nozzle.
    I wonder if the needle-nose plier squishing it a bit would create more of a fanned out spray or mist it more than the gush of water it does now. I'll adjust it (or have it adjusted) before I go this route for sure.
  8. rapoport3a
    rapoport3a Member
    Ontario
    Will try adjusting my nozzles. But the wipers themselves on my car are substandard, attached poorly, or both. They do not clean the windshield under almost all conditions.
  9. Andyw2100
    Andyw2100 Well-Known Member
    Ithaca, NY
    We live and drive in a very cold area and are constantly dealing with road spray and salt. We have the same problem as the OP. We have not tried adjusting the nozzles, as we don't live near a service center. The first time the car is at one I'll ask to have them adjusted, but I fear the "blob" problem will persist, resulting in far more washer fluid being used, and a still ineffective cleaning of the windshield.
    As for the blades themselves, I am optimistic that thanks to better blades ordered based on information found in the following thread, the windshield may wind up somewhat cleaner.
    P85D wiper blades
    I ordered these blades, but have not yet installed them.
  10. cwave1
    cwave1 Member
    Mississauga, ON, CANADA
  11. eco5280
    eco5280 Member
    Country
    My car is brand new and the wipers possible stink. But as I've said it might just be the washer nozzles. But I wanted to add I do have the newest of new cars so if my wiper performance isn't great the new wipers aren't solving the problem.
  12. mknox
    mknox Well-Known Member
    Toronto, ON
    I agree. Chrysler products of that era used them as well. They worked for me even in the deep freeze of Canadian winters, but the trick was to use the best washer fluid you could buy and to give them a little squirt every once in a while, even if you don't need to clean the glass. If you left them for a long time either the alcohol would evaporate or water would migrate up the lines causing them to freeze. Well worth it to get the uniform spray coverage.
  13. Andyw2100
    Ithaca, NY
    As per posts in the thread I linked to upthread, the wiper blades on the new cars are made by Bosch, but are not the Bosch Icon blades. A poster in that thread swapped out his new Bosch blades for Bosch Icon blades and saw a substantial difference.
  14. robaross
    robaross P4550
    SFL
    I assume these are only for newer models. Amazon says they do not fit my 2012.
  15. eco5280
    eco5280 Member
    Country
    Their vehicle matching system is unreliable at best. Any wiper blade will fit any car if it's the right length. (Here comes someone with some obscure exception :) )
  16. Andyw2100
    Ithaca, NY
    I'm fairly certain the blades will fit your car. The same blades referenced in this thread are referenced in several older threads, dating pretty far back. Do some searching just to be safe.
    For what it's worth, Amazon also says one of them won't fit my car, which is a new P85D.
  17. CHG-ON
    My wipers are stock from Sept 14 and they seem to work just fine. It's just the nozzles that don't work as well as they could. I did coat my windscreen with Opti-glass. Not sure if that makes a difference.
  18. slcuervo
    slcuervo Member
    France
    I personally think the wipers are OK. There are probably better ones out there, but so far, mine have been OK (car bought in Norway in May 2014).
    What is defenitely rubbish is the washer nozzles. Why in hell did they not choose to install those nozzles that spray a mist over the whole windshield? That's the best!
    Anyone knows if the nozzles can be replaced by ones that spray mist?
  19. mknox
    Toronto, ON
    Good point. My last car would spray in a kind of semi-circular arc across each side of the glass as opposed to the two little streams you get on the Model S.
  20. TaoJones
    TaoJones Beyond Driven
    The Americas
    Mine were and are as the OP described.
    Have gone through at least 3 gallons of fluid in 9 weeks. Service appointment this week to replace the wipers, hopefully adjust them so that *all* of the driver's side is cleaned, and to adjust the spray pattern and volume.
    Does not inspire confidence. Hopefully Service can once again save the day.
