Washington Post Tesla Fire hit piece
Sep 23, 2020
395
335
Sacramento CA
The sad reality is that 98% of media -- whether it's CNN Fox OANN etc etc etc - always focuses on the negative. Media digs up the dirty laundry because that's what most of the world likes to see / read / hear.
It's not Tesla centric. But since Tesla is ripe for the pickings - it gets a lot of slugs in the stomach.
Reactions: 2101Guy
trayloader
315
369
GERMANY
Tesla uses the legendary R1234yf coolant, which is the culprit for various fires in the car industry for years.
Here´s the list of manufacturers who use it:
Current list of OEs that use R-1234yf refrigerant
It´s called the "killer coolant" over here in Europe, since when emitted in contact with water (read extinguish)
and air its transformed to the highly toxic hydrofluoric acid.
A nice leftover from the Daimler cooperation days.
Daimler themselves banned it in 2017 however:
Daimler employs safety system for R1234yf MAC
Reactions: Ciaopec
CyberGus
Not Just a Member
May 5, 2020
718
1,594
Austin, TX
From the story:
The firefighter “looked at me and he said, ‘You’re lucky you got out when you did, because you could have gotten stuck in there,’” Ahmad said. It raised similar concerns to the Florida crash involving Awan.
Stuck? There's a manual release on the inside of the door. And I'm pretty sure that first-responders are aware that glass the breakable...?
Chaserr
Hyperactive Hyperdrive
Sep 5, 2017
2,656
5,569
Logan
Agreed. And this fire doesn't seem to be anywhere near the battery. What lives behind the passenger front tire?
The battery "lives" there and the battery heat outlets are there. Look for yourself, that's where your battery has its serial number sticker, and the heat exchangers are the reason Tesla's car cover has ventilated front wheels (so heat can escape even if you cover it while supercharging).
The front doors are completely mechanical inside. the rears have electronic handles with a mechanical backup release but the fronts are just a normal handle. When my 12v died it took days for the new one to be delivered, so I rolled down the windows and opened the door from inside using the handle. No issues with no power, whatsoever.
395
335
Sacramento CA
That´s probably what this " journalist" creatively "condensed" out of the report.
The more I read about it, the more this smells.
Everything this guy EVER wrote about Tesla was demagogic, cliche ridden and false.
Check for Yourself, it´s almost comical:
https://www.washingtonpost.com/people/faiz-siddiqui/
The white glove from Jeff B. Hopefully Elon addresses this.
You're right !
Elon should go on twitter and ill-advisedly get into a whirlwind back and forth with some reporter from The Washington Post.
Since the guy went to Nebraska - Elon should pull out his book of Cornhusker put-downs.
He shouldn't focus on building new factories... fixing his company's service and customer communications issues... revamping the Model S.
2101Guy
1,252
1,100
Hit piece or not, it doesn’t inspire confidence in my 85D.
This is pretty common these days. Persons opt to go with whatever the "news" headline is that day vs using critical thinking skills to research (in this case) if Tesla's are MORE susceptible to fire than gas car.
Because if they did use critical thinking skills and analyze? They would probably find that the numbers/facts show, that you should be in more fear of your ICE car catching fire, than a Tesla...
Mhoepfin
162
119
Atlanta, GA
Thanks for saying I don’t use critical thinking, who do you think you are? I actually own an 85D which I’ve seen get nerfed and the charging curve flattened more and more. There’s a reason and there’s a problem.
SO16
2,657
8,504
Supercharging is hard on the early cells over time. No surprise there. Unrelated to fire after damage though.
Reactions: 2101Guy
brucet999
2,671
1,482
Huntington Beach, CA
A coolant fire? Coolant is not flammable.
The most common coolants like ethylene glycol or propylene glycol can burn, but their flash points are in excess of 200ºF, so would not likely catch fire from sparks. Does anyone know what the battery coolant temperature of a Tesla is? I suspect much less than 200ºF.
Chaserr
Sep 5, 2017
2,656
5,569
Logan
45C max. while chemically possible for coolant to burn at a much lower temperature (it's alcohol in a water mixture, so submerging it in the battery could possibly electrolyze enough water into gas to bring down the ignition temp) it isn't a coolant fire. it's just not probable.
The 85s have had a rash of fires like this for the last few years. Tesla responded to them the same way GM did with the Bolt fires - they reduced maximum charge capacity. Except Tesla didn't recall so some cars never updated, some paid to downgrade, and some keep catching on fire. The next time you see a parked car with an 85 battery, listen to it. if it has an affected battery you will be able to hear it humming if the battery is over 70% charged. Maybe lower, since this car burned at 69%. That noise is the coolant pumps running - not to actively cool, but to cycle the coolant constantly and avoid any cells building up heat internally. Also, to hopefully detect a runaway cell by looking for a section of the battery heating up more than the rest.
Teslas burn far less often than gas cars, but 85s have a known defect that causes spontaneous combustion.
Reactions: Droschke
Chaserr
Sep 5, 2017
2,656
5,569
Logan
60s have the same battery chemistry but seem to be less affected. The hypothesis right now is 60s don't have the two front modules stacked on top of one another and maybe that is the problem spot (the other 14 are side by side). That's the narrower section of the battery between the front wheels. Until Tesla issues a recall with more info all we know for sure is they know about the fires and took drastic but secret actions in response to fires but these battery fires still happen. We need a recall for disclosure to know if any of it is actually safe and if people who aren't updating are still unsafe. Tesla has done software update recalls before so this one is probably hardware on top of the downgraded software changes, and batteries are expensive do they haven't done a recall.
Reactions: Droschke
