I googled the problem and saw that is well known, but so far I haven't seen and DIY solution.
Problem statement: when it rains, if I open the trunk water gets into the trunk as if it is a gutter collector. Water is coming in not only from the trunk that is opening, but also from the water that slides from the rear window. When the trunk is closed no probelm
Has anyone been able to fix the problem?
Does anyone have a solution apart not opening the trunk or parking in a slope with the point of the car towards the bottom?
Thank you all for your help
