Yes, my car had that problem. Usually when washing the car, rather than from rain. Tesla service fixed it for me under warranty. They don't need to replace the seals, just raise them and/or adjust the deck position.I notice that I'm getting water into the trunk area, particularly on the left edge. Anyone else have this problem? Maybe I just need new seals.
I don't recall a noticeable difference. The seals slip onto the top edge of the bucket that forms the trunk. The way they can raise the seal is to take it off, slide some edging onto the edge of the bucket, then put the seal on back over the edging. Thus, it looks the same before and after. At least that is how I think the process went.That seemd like an easy fix. Do you recall how any of the seals on that side looked like prior to the service?
I have had it in my 1.5 Roadster. The water does seem to come in on the left/driver's side of the car. I haven't figured out where it is getting in, but it seems to only ocur when I wash the car and even then it is sporadic. ...
Are you sure? I live in a humid climate but I've never had condensation in my trunk. Or leaking in over 60k miles. OK, I know that doesn't compare to what you've done, so maybe I just haven't seen it yet?Do not forget that the temperature in the trunk varies a lot through the temperature of the electric motor nearby (more then 100 degrees Celsius while driving) and the PEM
This causes a lot of condensation in the trunk and is not a leakage
