Water under the Model 3?
Discussion in 'Model 3' started by minsup23, Aug 16, 2018.
  1. minsup23
    minsup23 Member
    Chicago, IL
    I was doing some cleaning and applying the center console wrap in my Model 3 today. I got hot and I did put the A/C on 1 despite the video saying not to, but I gave in. I noticed a huge amount of water coming from the bottom of the car and into my driveway as seen below
    I took a picture of below the car as well:
    Here are two videos as well to see the water or whatever liquid dripping under the car:
    https://photos.app.goo.gl/6daJDiU55pmdcUGY6
    https://photos.app.goo.gl/HAocr4udQWGRYpuUA
    I want to say this is A/C condensation, but want to make sure this is what is going on. Appreciate help and advice. I will hopefully be contacted by my SC soon to get some paint fixes and they can look at it as well. Just wanted to make sure it's nothing crazy or scary.
  2. streetskooler
    streetskooler Member
    NJ
    Hey that happens to mine too. I think it’s just the compressor from the A/C. Happens on almost all cars I’ve noticed but def seems to happen a lot with the model 3. I wouldn’t be too concerned
  3. tccartier
    tccartier Member
    AZ.
    That's been happening since cars have had air conditioning. Every other car you have had has done it too. It's the moisture in the air condensing out as it passes over the cooling coils in the evaporator. It's allowed to drain out.
    Same reason why a cold drink will sweat.
  4. minsup23
    minsup23 Member
    Chicago, IL
    Okay, it should seemed like a lot for low AC and have not noticed this with my Honda Accord or Honda Pilot. I was maybe outside for an hour?
  5. tccartier
    tccartier Member
    AZ.
    #5 tccartier, Aug 16, 2018
    You probably didn't sit and idle your Honda Pilot or Honda Accord with the air conditioning on for an hour letting the gas engine run very often.
    Also the amount of drainage is directly related to the amount of moisture in the air. days with higher humidity would produce more condensate than days with much lower humidity.
    Enjoy your Model 3!
  6. Shizzrock
    Shizzrock Member
    Boston
    If it was transmission fluid I'd be worried
    • Funny x 2
  7. Kermee
    Kermee It's Not Easy Being Green
    WA, BC & HKG
    This is what happens when you don't potty train your Model 3 before you bring it home from the Service Center...
    Kidding aside, like everyone mentioned above, I'm 99% sure it's water from the AC compressor.
    • Funny x 2
  8. zackmilo
    zackmilo 2.2M+ Youtube views on my Model 3
    Los Angeles, CA
    Maybe he saw a pic of my model 3?
    jk its normal
  9. minsup23
    minsup23 Member
    Chicago, IL
    Oh man! Totally makes sense...never idled in the above cars at all.
  10. Twiglett
    Twiglett Single pedal driver
    Austin
    Its in the manual, Page 93
    It is normal for a small pool of water to form under Model 3 when parked. Extra water produced by the dehumidifying process is drained underneath.
  11. Trevor B
    Trevor B Member
    What video says not to turn on AC? o_O
    The condensation is a lot more than ICE ... for good reason.
  12. minsup23
    minsup23 Member
    Chicago, IL
    :confused: I’m not good with emojis. Thank you all!
  13. TT97
    TT97 Active Member
    Los Angeles
    The instructional videos for installing center console wraps typically recommend turning off the fans so as to not interfere with the installation (nothing to do with standard operation of the car).
  14. rjcbox
    rjcbox Member
    PA, USA
    >99% guess it's AC condensation, completely normal
  15. ibdb
    ibdb Any excuse for a road trip
    Puyallup, WA
    You'll probably notice more water under/around your car in the garage after it rains, too. Lacking an ICE, there's no excess heat that helps to dry up some of the moisture commonly found around your car, whether from the A/C or the weather.
