WAXING FREQUENCY
Discussion in 'Model 3' started by STEWIE 911, Nov 10, 2020.
  1. STEWIE 911
    STEWIE 911 Member
    Bracebridge , ont
    If I am too busy ( lazy ) to wax with Mothers and use a car wash liquid wax......how long will it last ?
  2. cdswm3
    cdswm3 SR+
    Canada
    Hours, maybe days.
    Do a DIY ceramic coat. Last a couple of years.
  3. UncertainTimes
  4. bwbrs
    bwbrs Member
    NJ
    #4 bwbrs, Nov 10, 2020
    If anything, get a spray on sealant like Gyeon Wetcoat or Carpro Hydro2, or something similar.
  5. Webeevdrivers
    Webeevdrivers Active Member
    Canada
    If you are tight for time consider using Maguiars ultimate quick wax once per month. It’s a spray on product. It will stand up pretty good. Make sure you wash it really good first.
  6. JulienW
    JulienW Active Member
    Atlanta
    NEVER since I ceramic coated mine. It is "waxed" all the time.
  7. Dolemite
    Dolemite is my name
    ol' Virginny
    Get a coating. I'd rather spend an entire weekend thoroughly applying 2x coats of a quality ceramic coating every 2 - 3 years, than doing that *sugar* every few months.
  8. SageBrush
    SageBrush REJECT Fascism
    New Mexico
    No thanks
    I spend a couple of hours twice a year giving the car a waxing. May not be up to standard but it is good enough for me.
  9. Apprunner
    Apprunner Member
    So-cal
    Or you can use Opti-seal once a month. The stuff lasts a couple months but once a month ensures complete protection and it takes 5-10 minutes to apply as its wipe on, walk away.
  10. iSpine
    iSpine Member
    East Coast
    get some sonax spray and seal
  11. LACALawyer
    LACALawyer Banned
    Find some idiot kid and promise to teach him karate.....your car, fence and deck will never look better.
    • Funny x 7
  12. calidreamz808
    calidreamz808 Member
    Huntington Beach, CA
  13. STEWIE 911
    STEWIE 911 Member
    Bracebridge , ont
    THANKS FOR ALL THE INFO. I have used Mother's on my Model 3 June 10th , July 25th and Nov 8th for the winter.
    Will consider options above next spring.
  14. hellocar
    hellocar Member
    New Jersey
    I use P21S a couple times a year. Gives the car a great luster and shine, and doesn’t do anything permanent / weird to the paint that i would need to worry about. I agree it’s a bit of work each time, but don’t have to do the roof like my last car!!
  15. Candleflame
    Candleflame Active Member
    QLD, Australia
    Imho depends where on the car and what chemicals get used for cleaning (and how often).
    The worst is imho bugs (so front of the car) and bug remover setc.
    Spray sealant usually lasts 4 months, applied sealant 5-6 months, wax maybe 1-2 months. In my experience.
  16. Candleflame
    QLD, Australia
    i didnt used to be fan of ceramic coating but my view has changed now and I think a cheapish ceramic coating (which may not look perfect, i.e. only basic paint correction) is the way to go now.
  17. JulienW
    Atlanta
    Here is my previous car (Cadillac ELR) after over 2 years after a rain. I did the full meal deal on both cars and it takes the better part of 2 days. But it will net less over all time than waxing every couple of months.
  18. zhu-
    zhu- custom title
    NJ
    Honestly liquid waxes / waterless washes are not bad at all and I've been using them almost exclusively now.
    With green ONR, I've found if you use 2-3x the recommended amount, that stuff shines and beads rain for a surprising long time. For the first 2-4 weeks after it rains the car looks virtually freshly washed if dust or pollen doesn't dry on the paint. I haven't washed my car in two months now and the rain still beads and slides down mostly the same as after a wash.
  19. Fernand
    Fernand Active Member
    Northern california
    With the green ONR+W if you use a spritz of Opti-Seal per panel as you dry, it's even better.
    This method is less work than any kind of actual waxing, because the "removal" phase + polishing phase is just the drying, and the lubricating action of the Opti-Seal makes that effortless. And it shines like a motha'. And lasts. I used to be a carnauba waxer, but this even looks better.
  20. alexgr
    alexgr Member
    Tulsa
