Is "Range Badging" just to simplify messaging for the mass market or is it a way for Tesla to improve margins on the cars?
We Don't Need No Stinking Badges
I think it is both.
I think it is both.
If you're gonna do that, might as well go with: P120DP120D on a 3-d printer is a snap.
Robin
In my opinion, both, and neither. I think the move away from even mentioning the battery capacity frees Tesla to capitalize on improvements in efficiency, and therefore the ability to deliver range with less battery capacity (and cost), by removing the battery capacity as the most visible measure of a car's capability. The standard Model 3 would seem a lot less of a car if we knew that the battery was only 50-something kwh, even though it's a car with a solid 220 miles of range. Same with the LR model, which we'd all be comparing with the 70 or 75kwh Model S, even though it soundly trounces both.Is "Range Badging" just to simplify messaging for the mass market or is it a way for Tesla to improve margins on the cars?
I think it is both.
If it's worth doing, it's worth overdoing! P120BFDIf you're gonna do that, might as well go with: P120D
In that case I'll remove the T in back and but a Ferrari horse back there.If it's worth doing, it's worth overdoing! P120BFD
Tesla owner, long time Tesla investor, EV driver since 2007. What is it that you think is "not known"?Which shows they don't know anything about Tesla.
Why not simply make it "58" kw and call it close enough for office work?My 3 will be GETTING badges once I get it. I was not consulted about removing the badges, I do not approve, and my 3 WILL HAVE BADGES!!! The "Model" badge from an S, the small battery seems to have around 55 KW of capacity between usable range and anti-bricking buffers, so I will go with 2 "85" badges from an S, and make a 55, then cut the 8 into a 3. Since I will have 2 8's, I get 2 chances not to screw it up.
I'll use blue masking tape on the back of the car to get everything straight. I got this all figured out. I did it while at work.
