It depends on your definition of the length of a “road trip”. I think that the very cogent analysis by @Zoomit is on point in terms of driving from SC to SC, and applies to trips of 400 miles/day or more (which many people do). I agree with you that for a “road trip” of say 400 or less your point is valid, except...My point is that, if you go on a road trip in an EV, you have the option of arriving at your destination (or nightly stop-over point) with a relatively low SoC, just as you can do at the end of a day of commuting and running errands. This option reduces the need for high DC fast charging rates, and by a quite significant amount.
Yes, you can find them, but PlugShare does not tell you if they are properly maintained and in good working order or if they are in use. Since L2 charging points are usually available in very low quantities at a specific location (one or two plugs) you cannot count on them. The situation is improving, but slowly. Superchargers are much more reliable.As to "no planning is required to find a Level 2 plug at night," those are becoming quite common, and I wouldn't be surprised to start seeing them noted on highway signs that announce lodging before too long. This will make finding them trivially easy. Even now, you can find them with PlugShare without all that much effort.
Certainly Superchargers are more reliable (as are destination chargers), but there are many places where there aren't Superchargers, or they are too far apart, or there is no redundancy. For example, a few weeks ago the Salina, KS Supercharger worked but couldn't be reached due to flooding--the only road to it was barricaded (probably didn't help Holiday Inn's business either). Because there are no SCs between Salina, KS and Lincoln, NE (a distance of ~200 miles), alternative charging locations needed to be used. Superchargers can't be 100% relied on until the network builds out enough so one incapacitated SC location doesn't force alternatives. That is still a very long ways away (unless you only travel in California).Yes, you can find them, but PlugShare does not tell you if they are properly maintained and in good working order or if they are in use. Since L2 charging points are usually available in very low quantities at a specific location (one or two plugs) you cannot count on them. The situation is improving, but slowly. Superchargers are much more reliable.
As EV's become mainstream, purchased by "normal" people, not just EV enthusiasts,
You think Miles per Gallon made any sense to people coming from a horse? Or Megabytes to people coming from file cabinets full of paper? kW and kWh is fine. 'Normal' people just need to learn how 'new' technology works.
How are kw and kWh fine? Those values alone tell you nothing? You need a rate/time.
