  • TMC Podcast #11 will stream live Saturday at 1PM PDT. We will be joined by special guest JT Stukes, a former engineer at Tesla. You can watch it live and participate in the chat on YouTube. We will addressing viewer comments and questions. For more information, follow the TMC Podcast #11 thread.
We need spare parts for Tesla X
2 MX BRKT HEADLAMP INNER LH MX BRKT HEADLAMP INNER LH 1046957-00-E 1
3 MX BRKT HEADLAMP OUTER LH MX BRKT HEADLAMP OUTER LH 1046958-00-D 1
4 MX BRKT HEADLAMP INNER RH MX BRKT HEADLAMP INNER RH 1046959-00-F 1 OK to use 1046959-00-E
5 MX BRKT HEADLAMP OUTER RH MX BRKT HEADLAMP OUTER RH 1046960-00-D 1
8 MX FASCIA FENDER BRKT RH MX FASCIA FENDER BRKT RH 1047093-00-H 1 OK to use 1047093-00-G is washer is present
12 ASSY, MX DUCT FR.FOGLAMP LH ASSY, MX DUCT FR.FOGLAMP LH 1 not currently available
13 MX DUCT FR.WHEELHOUSE INJECTION UPPER LH MX DUCT FR.WHEELHOUSE INJECTION UPPER LH 1 not currently avaialble
14 MX DUCT FR.WHEELHOUSE INJECTION LOWER LH MX DUCT FR.WHEELHOUSE INJECTION LOWER LH 1 not currently available
* ASSY, MX DUCT FR.FOGLAMP RH ASSY, MX DUCT FR.FOGLAMP RH 1043931-00-D 1 contains #15, #16 and #17
15 MX DUCT ASSY FR.FOGLAMP RH MX DUCT ASSY FR.FOGLAMP RH 1
16 MX DUCT FR.WHEELHOUSE INJECTION UPPER RH MX DUCT FR.WHEELHOUSE INJECTION UPPER RH 1 not currently avaialable
17 MX DUCT FR.WHEELHOUSE INJECTION LOWER RH MX DUCT FR.WHEELHOUSE INJECTION LOWER RH 1 not currently available
19 MX FOG LAMP PARKING UPPER SPEAR LH MX FOG LAMP PARKING UPPER SPEAR LH 1049609-00-E 1 OK to use 1049609-99-D
20 MX FOG LAMP PARKING UPPER SPEAR RH MX FOG LAMP PARKING UPPER SPEAR RH 1049610-00-E 1 OK to use 1049610-99-D
21 MX FOG LAMP PARKING LOWER SPEAR LH MX FOG LAMP PARKING LOWER SPEAR LH 1049611-00-E 1 OK to use 1049611-99-D
22 MX FOG LAMP PARKING LOWER SPEAR RH MX FOG LAMP PARKING LOWER SPEAR RH 1049612-00-E 1 1049612-99-D
28 FRT Wheel Fairing Asm RH FRT Wheel Fairing Asm RH 1054804-00-C 1
1 FRONT UPPER GRILLE CARRIER MX FRONT UPPER GRILLE CARRIER MX 1047020-00-D 1
4 MX CENTER FASCIA BCKT MX CENTER FASCIA BCKT 1055069-00-E 1
5 FRONT UPPER GRILLE MX FRONT UPPER GRILLE MX 1050143-00-D 1
10 MX ASSY FR T BADGE MX ASSY FR T BADGE 1047884-00-D 1
12 MX LOWER FRONT GRILLE MESH MX LOWER FRONT GRILLE MESH 1047734-00-F 1
13 PANEL, UPPER CLOSING, FASCIA, MX PANEL, UPPER CLOSING, FASCIA, MX 1047360-00-E 1
14 PANEL, LOWER CLOSING, FASCIA, MX PANEL, LOWER CLOSING, FASCIA, MX 1047740-00-F 1 OK to use 1047740-00-E
15 MX FR Tow Hook Cover MX FR Tow Hook Cover 1057056-00-D 1
4 MX ANKLE CATCHER ASY LH MX ANKLE CATCHER ASY LH 1061424-00-B 1 OK to use 1061424-00-A
5 MX ANKLE CATCHER ASY RH MX ANKLE CATCHER ASY RH 1061425-00-A 1
2 ASSY - FRONT FENDER, RH, ECOATED Restricted FRONT FENDER ASSEMBLY - RIGHT - SERVICE ECOATED 1069534-E0-A 1 Structural - Approved Body Shop Only
1 HOOD SEAL HOOD SEAL 1033016-00-B 1
2 SEAL, HOOD TO COWL SEAL, HOOD TO COWL 1036246-00-B 1
3 SEAL, HOOD, FR SEAL, HOOD, FR 1047613-00-A 1
2 LINER-WHEELHOUSE FR RH MDL X LINER-WHEELHOUSE FR RH MDL X 1034250-99-F 1
3 FENDER BAFFLE RH MX FENDER BAFFLE RH MX 1037732-00-B 1
1 AERO SHIELD, FRONT AERO SHIELD, FRONT 1035158-00-C 1
1 ASSY, FENDER GARNISH FR, RH MDL X ASSY, FENDER GARNISH FR, RH MDL X 1035289-00-G 1 not currently available - use 1078209-00-A.for vehicles manufactured on or after December 12th, 2015. compatible with front fascia 1034837-00-G. includes sensor and retainer ring.
1 MOULDING APRON FRONT MDL X MOULDING APRON FRONT MDL X 1036235-00-E 1 not currently available
2 SCUFF PLATE. FR APRON MX SCUFF PLATE. FR APRON MX 1048618-00-B 1 not currently available
4 MOULDING APRON LH MDL X MOULDING APRON LH MDL X 1036236-00-F 1
5 MOULDING APRON RH MDL X MOULDING APRON RH MDL X 1036238-00-F 1
7 MOULDING APRON REAR MDL X MOULDING APRON REAR MDL X 1036241-00-D 1 not currently available
8 ASY HOOD HINGE COVER LH MX ASY HOOD HINGE COVER LH MX 1064602-00-B 1
11 RETAINER HOOD HINGE COVER LH MX RETAINER HOOD HINGE COVER LH MX 1063006-00-C 1
12 RETAINER HOOD HINGE COVER RH MX RETAINER HOOD HINGE COVER RH MX 1063007-00-C 1
19 COWL SCREEN SPPRT BRKT COWL SCREEN SPPRT BRKT 1055405-00-B 1
1 MOLDING FRUNK MDL X MOLDING FRUNK MDL X 1036223-00-E 1
2 FRUNK CROSS MEMBER FRUNK CROSS MEMBER 1035176-00-E 1
3 MX HEADLAMP SUPPORT BRACKET LH MX HEADLAMP SUPPORT BRACKET LH 1043357-00-E 1
4 MX HEADLAMP SUPPORT BRACKET RH MX HEADLAMP SUPPORT BRACKET RH 1043612-00-E 1
5 MX FRUNK SAFETY RELEASE SWITCH BRACKET MX FRUNK SAFETY RELEASE SWITCH BRACKET 1062771-00-A 1
6 SWITCH, FRT TRUNK, CHILD SAFETY SWITCH, FRT TRUNK, CHILD SAFETY 1002066-00-A 1
1 FRUNK CARPET MX FRUNK CARPET MX 1048059-00-D 1
2 LIFTGATE PUDDLE LAMP, HI-INTENSITY LIFTGATE PUDDLE LAMP, HI-INTENSITY 1043893-00-A 2
1 FRONT RADAR, NO HEATER FRONT RADAR, NO HEATER 1057551-00-B 1
2 MX CNTR RADAR MOUNT MX CNTR RADAR MOUNT 1 not currently available. order 1047096-00-E.
5 MODEL X CENTER RADAR BRACKET MODEL X CENTER RADAR BRACKET 1 not currently available. order 1047096-00-E.
8 MX FRT RADAR BRKT LH MX FRT RADAR BRKT LH 1047097-00-D 1
5 SIGNATURE-LAMP ASY SIDE REPEATER (LH) SIGNATURE-LAMP ASY SIDE REPEATER (LH) 6007707-01-D 1
6 SIGNATURE-LAMP ASY SIDE REPEATER (RH) SIGNATURE-LAMP ASY SIDE REPEATER (RH)) 6007699-01-D 1
3 MX BRKT HEADLAMP INNER LH MX BRKT HEADLAMP INNER LH 1046957-00-E 1
4 MX BRKT HEADLAMP OUTER LH MX BRKT HEADLAMP OUTER LH 1046958-00-D 1
5 MX BRKT HEADLAMP INNER RH MX BRKT HEADLAMP INNER RH 1046959-00-F 1 OK to use 1046959-00-E
6 MX BRKT HEADLAMP OUTER RH MX BRKT HEADLAMP OUTER RH 1046960-00-D 1
1 BATTERY BACKED SIREN BATTERY BACKED SIREN 1015860-00-A 1
4 HORN, LOW TONE, MDLX HORN, LOW TONE, MDLX 1045496-00-A 1
2 FRONT UPPER GRILLE MX FRONT UPPER GRILLE MX 1050143-00-D 1
3 MX HVAC NOSE DUCT MX HVAC NOSE DUCT not available 1 order 1050223-00-D
4 MX HVAC NOSE DUCT RR-RC MX HVAC NOSE DUCT RR-RC not available 1 order 1050223-00-D
5 MX HVAC DUCT SEAL MX HVAC DUCT SEAL not available 1 order 1050223-00-D
8 MX ACTIVE LOUVER HOUSING LWR MX ACTIVE LOUVER HOUSING LWR 1
11 ASSY, MX DUCT FR.FOGLAMP LH ASSY, MX DUCT FR.FOGLAMP LH 1 not currently available
12 MX DUCT FR.WHEELHOUSE INJECTION UPPER LH MX DUCT FR.WHEELHOUSE INJECTION UPPER LH 1 not currently available
13 MX DUCT FR.WHEELHOUSE INJECTION LOWER LH MX DUCT FR.WHEELHOUSE INJECTION LOWER LH 1 not currently available
14 MX DUCT ASSY FR.FOGLAMP RH MX DUCT ASSY FR.FOGLAMP RH 1
15 MX DUCT FR.WHEELHOUSE INJECTION UPPER RH MX DUCT FR.WHEELHOUSE INJECTION UPPER RH 1 not currently available
16 MX DUCT FR.WHEELHOUSE INJECTION LOWER RH MX DUCT FR.WHEELHOUSE INJECTION LOWER RH 1 not currently available
