Website Math Error?
Discussion in 'Tesla, Inc.' started by jehan2256, Oct 13, 2017.
Tags:
  1. jehan2256
    jehan2256 New Member
    New Zealand
    I noticed something peculiar on Tesla's website today...
    It says that if you charge at 24A on a 3-phase circuit, you'll get 16.5kW of power.
    If we do some math...
    16500W/24A = 687.5V
    I don't know of any household circuit with such a high voltage.
    What's I noticed, however, is that 687.5 is approximately 3 times 230, which is the standard household voltage (in most countries).
    So it seems like whoever wrote this information was under the impression that 3-phase power gives you 3 times the voltage of single phase, whereas it actually gives you the square root of 3 (1.73) times the voltage.
    So, am I missing something, or did Tesla get their figures wrong?
  2. MasterT
    MasterT Member
    North Miami Beach, FL
    I'm not really an expert but I think you might be confusing calculations with line to line voltage (which uses square root of 3) with line to neutral voltage (which uses 3 times the voltage)
  3. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    It would be _400V_ 3 phase. Each phase is 400/3^0.5 = 230.94.
    400 x 24 * 3^0.5 = 16.627.
    (= 400/3^0.5/phase * 24A * 3 phases)
  4. McRat
    McRat Well-Known Member
    LA
    Yes, it's why 3ph kicks arse. There are 3 hots. Each one pulls amps.
    If EVs in the USA would accept the common 3-ph at a mear 24a (30a breaker):
    208vac 3ph = 3 lines x 24 amps x 120v = 8.6 kW
    480vac 3ph = 3 lines x 24 amps x 277v = 20 kW
    This can be done on a dedicated short run of 10 awg THWN-2 with 30a breaker. Cheap setup
  5. jehan2256
    New Zealand
    Thanks guys, that cleared up some confusion.
