Weird charging.. faulty?
Between yesterday and today, at around 40-50% SoC, the most I've been able to get at a super charger was around 20 kW.
Currently at 60% SoC, 20 kW, keeps dropping to 0 and back to 20, and the supercharger is at half capacity parked. Yes, the charger is "in".
Anyone else notice this?
What’s the top charge rate on this supercharger? 72kw or 150kw? Are you sharing the stall next to you? For example 1A and 1B, if you show up after someone is using the other paired charger you could see lower KW charging. Plus you’re more then half full, on average I will see no higher then 55kw and it will drop fast in the 30’s
Fred
