Weird foam coming from crack in garage floor
Discussion in 'Off Topic' started by Kipernicus, Feb 12, 2014.
Tags:
  1. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    Noticed this dried up foamy stuff under the car, like it dripped off and crystallized. Not salt (bay area).
    Maybe residual car wash soap? I go to Foster City touchless, but it has been weeks since I last went. Or something else I picked up from the road?
  2. Kalud
    Kalud Active Member
    Montreal, QC
    Looks like fungus to me, probably not from the car itself but more from the garage floor + water / humidity from the car...
  3. Hybris
    Hybris Member
    Sweden
    cocaine?
  4. EdA
    EdA Model S P-2540
    Massachusetts
    Road salt...you should see my garage.
  5. AMPd
    AMPd Active Member
    Northern California
    Now that's what I call a car paying for itself!
  6. tezco
    tezco Sig P85
    Colorado
    Looks like concrete efflorescence.
  7. TurboFroggy
    TurboFroggy Member
    Everett, WA
    Yeah that and stripper glitter keep building up in on the back seat of my P85.
  8. SFOTurtle
    SFOTurtle Active Member
    Los Altos, CA
    Road salt in the SF Bay Area?
  9. jdevo2004
    jdevo2004 Member
    It is AL2O3. A few more years and you wont have much of a car left!
  10. Kipernicus
    Belmont, CA
    It's interesting that it doesn't happen under my wife's car (acura tsx). For some reason the water dripping off the MS is causing efflorescence but water off the Acura does not? Anyone else seeing this?
  11. jdevo2004
    jdevo2004 Member
    I just said it, your car is rusting from the inside out. Aluminum Oxide.
  12. Joe H.
    Joe H. Member
    VA
  13. artsci
    artsci Sponsor
    Timonium, Maryland
    Looks like something you could get high on:)
  14. tezco
    tezco Sig P85
    Colorado
    Perhaps salt was previously deposited in only that parking space.
  15. Joe H.
    Joe H. Member
    VA
    I was trying to link to another thread where a similar "white powder" has shown up (much smaller amounts) in other peoples car and they are speculating corrosion as well. Look at page 2 of the "My baby got hurt :(" post under the main Model S forum. Now that is a lot of powder so let's just hope it is salt or cocaine.
    My other post said it was waiting for mod approval and I guess it never got approved.
  16. lorih
    lorih Member
    Kip, there is a lot of speculation here. Did you bring the car, and a sample of the white stuff to Tesla service to see what they think? That seems like the reasonable thing to do.
    (Speaking of reasonable, if I didn't know how reasonable and well behaved your sons are, I would have said it is just laundry soap they put under your car to play a prank on you, but your kids are too well behaved for that.)
  17. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    This is lime salts leaching from underneath your slab. It is due to excess moisture underneath your slab, and/or improper moisture barrier applied underneath it. It has nothing to do with your car! In the summertime see if you can improve the drainage away from your house to keep the soil drier.
  18. lorih
    lorih Member
    That's the best suggestion I've seen here, and easy to test. Clean off the garage floor, switch parking spots with wife's car, and see if it comes back.
  19. Zextraterrestrial
    Humboldt/Los Altos
    or put a bit of acid on it and see if it bubbles.
    or not since aluminum oxide will react w/ both acid and base...bad test
  20. lorih
    lorih Member
    Chemistry...cool!
