I did not have Range Mode on the few times it has happened to me. Moving to another stall solved it, so it is not related the car or its settings.
I have had that problem and switched stalls and everything went well thereafter.I was supercharging at a Service Center late last night. It was about 90 out. It started off great, pulling around 290 Amps, 400 volts. After about 20 minutes (when SOC was like 30-40%) the amps dropped off to 74 (volts remained around 400) and would not exceed 74 for the rest of the charging session. Took forever to charge the rest of the way! The other stalls were empty so it wasn't a case of a paired supercharger. Very odd. Did my car or the supercharger equipment malfunction? I've used this stall in the past and no issues.
Doubt it's relevant, but I'll also note I got a software update available around the time the amps dropped off (2.28.19 --> 2.28.60). I didn't install it until after I got home after supercharging. Any ideas?
Only conspiracy theorists think they're being "throttled" when there is an issue with supercharging.
Its definitely not a range mode issue. I run range mode on long trips and never had a low amp issue that wasn't corrected by moving to another stall. I can also attest the range mode has no control over cooling circuit fan speed During hot summer days on a trip at superchargers Fans definitely ramps up to max.
Me, too -- on July 19 at Hawthorne, NV.I have had that problem and switched stalls and everything went well thereafter.
Like I said, I witnessed it myself. Fans refused to run in range mode, ran perfectly fine the next day at the same supercharger under similar temperature conditions with range mode off.
I think it is simply coincidental that the first day it didn't work you were in Range Mode and the second day when it did work you were not in Range Mode.
I hope we are taking into account whether there is another TESLA plugged in at the station? Remember every "charger" is actually linked to 2 cords/spots, if you plug in to one that has its partner (4A and 4B are partners for instance) in use then you will only get around 20% of the power until the partner is done charging then it will taper you up as they taper down...
I had a similar issue driving back from Fremont on Monday in our brand new Model X.
Gilroy was fine, but both Harris Ranch and Buttonwillow seemed to be limited to about 30-40 kW even at low SoC. On plugging in, I initially got almost 100 kW but after a minute or two the amps steadily dropped down. Pretty sure it is temperature related as it was 105+ degrees.
For the record, these Superchargers are not local to me in Los Angeles and I was not in range mode.
I experienced the same thing on my last two trips through Harris Ranch--charging not exceeding 50kW or so (not paired) when it's 100+ outside. This is my first summer with my 70D (took delivery in November of last year) and the only long trip that I regularly take is up I-5 to San Jose and back... it's a little frustrating, given that it practically doubles the amount of time I have to spend at Harris Ranch. Everything was awesome during the fall/winter and spring.I had a similar issue driving back from Fremont on Monday in our brand new Model X.
Not paired here either. As a matter of fact everytime it happened to me I was the only one at an eight stall location. Changing chargers (i.e., moving from 1x to 2x or 3x) usually cured it.
My supposition is that the chargers are overheating. Perhaps the cooling intakes or filters are dirty over time because I don't remember seeing this happen last year. You plug in, get the high, normal rate and then it drops down quickly as the chargers get too hot. I've even seen it charge at 117 kW for a few minutes, hear the full array of cooling fans spin up in the car, then have it drop down to 35 kW and the car's cooling fans drop back to inaudible.
Mike
The issue was Range Mode: If you leave range mode turned on, the forced cooling fans do not run -- the car attempts to cool everything through the passive radiator, and that's not enough on a hot day. The charging rate will be limited due to high battery temperature.
