Wetspot / Leak
Discussion in 'Model S: Interior & Exterior' started by lloyds, Jun 3, 2014.
  1. lloyds
    lloyds Member
    Bay Area
    #1 lloyds, Jun 3, 2014
    Well this certainly sucks. Anyone else? Took it to a drive thru touchless car wash as my detailer couldn't make out to do a wash. As soon as the wash was nearly done, I noticed my laptop was wet. I thought it was maybe water from my water bottle, but after wiping it up, more dripped down to my computer. By this time, I realized there was an excessive amount of water on my laptop and it kept dripping from the roof. Now there is a spot on the roof approximately 4" diameter that seemed to have stained from the water. Now my computer is running weird and there is a wet / dryspot on the roof liner, which seems to be permanent. I'm guessing that there must have been other cases of this happening. I just want to know if this dryspot is permanent because it is pretty ugly now and want to know what Tesla did to address this
    I've searched, but haven't found anything.
  2. huntjo
    huntjo Member
    Fort Collins, Colorado
    Not good! Must be some seal leaking. Would this be warranty or insurance? Either way I don't envy the headache it will be to fix
  3. caddieo
    caddieo Member
    Palm Coast, FL
    Since you have a pano roof, the entry point might be somewhere along its seals.
  4. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Usually when something like that gets a water stain it's there for good unless you can wash the whole surface uniformly. The far greater concern, in my opinion, is where is the water coming in and where else did it go? Can't say I've seen any other complaints like this. Is it possible the roof didn't close all the way? Did you notice when you got out? Otherwise I guess the water jets just shot water past the seals. I got to touchless washes pretty regularly with mine and never had an issue (though I do tape up the roof rack mounts).
    The car is warranty, the laptop likely insurance, unfortunately.
  5. lloyds
    lloyds Member
    Bay Area
    Yes, I double checked on the roof being closed as soon as I saw water dripping in. I was still in the car wash when this happened as I was frantically wiping the roof and my laptop with my hand as I didn't have any tissue or towel. Waiting to hear back from Service. I really hope the waterspot stain is not permanent. I'm guessing it's a seal issue, so this could be fixed, but the entire headliner?
  6. Gizmotoy
    Bay Area, CA
    They'll likely just replace it. They're going to have to take it off to investigate, anyway. They very probably won't want to deal with the possibility of mold, etc. growing in there.
  7. wamochi
    wamochi Member
    San Diego, CA
    wow. great that you took the video. no way they can dispute what's happened or say "could not replicate".
    hope it works out. i agree with gizmo - they will remove the whole headliner and replace it with a new one after they've determined the cause of leak and fixed it.
    things like this are really scaring me about the pano roof :eek:
  8. vgrinshpun
    vgrinshpun Supporting Member
    PA
    I had a leak, also after touchless car wash, from the area just above the small pillar separating the rear passenger side window and the rear small triangular fixed window. It took two attempts/trips top the SC, but it is fixed now. The work order states that a butyl tape was applied to the channel to fix the leak.
  9. lloyds
    lloyds Member
    Bay Area
    that's a great point. I never even thought about the potential of mold. Thanks!
  10. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Try Oxyclean. It works well on fabric seats and headliner in aircraft. Try a small place first in a non-visible area.
  11. cgiGuy
    cgiGuy Active Member
    Sacramento, CA
    Is that blood on your seat? You might have worse problems..
  12. lloyds
    lloyds Member
    Bay Area
    Just heard back from Tesla. Will be taking the car in next week. Was told may take several days. I really hope the headliner doesn't need to be replaced and can just be cleaned. I've tried various products, but nothings getting rid of that water ring.
  13. vgrinshpun
    PA
    Ha, no problems here - this is just dirty iPhone camera lens.
  14. darthvdr
    darthvdr Member
    los gatos, ca
    Sorry to hear. I have had issues with water leaking from the driver's side lower corner of the door. Was a seal issue and taken care of by the dealer in my last visit. Hope it all gets resolved for you properly.
  15. Alysashley79
    Alysashley79 Member
    Seattle, WA
    #15 Alysashley79, Jun 6, 2014
    i had the same thing happen however mine came in through one of the small windows in the he back I called the SC right away and told me about it and they found the source of the problem...then replaced my liner. They MUST replace th liner because there is water that is sitting up under the liner so it needs to be cleaned out and dried properly they will have to remove your front windshield and replace it (they will pay for all of this) and if you have any film or tint on tot they will also pay to have this replaced at the place of your choice.
  16. lloyds
    lloyds Member
    Bay Area
    Thanks! How long did it take for the repairs / replacements? Sounds a bit more involved than I was hoping.
  17. Alysashley79
    Alysashley79 Member
    Seattle, WA
    It took them about a day to fix the actual seal that was bad (with drying times for the sealer product and testing of it etc). And since they were going to be replacing the liner I gave them the OK the bend the bad liner down the middle to clean any water that had accumulated under the liner (there was quite a bit and from your pic I'd say you probably have quite a bit as well) it took them about a week to get a new liner in from fremont and a new windshield the replacement of those two things took maybe three hours tops. And then another day for the windshield film I had on my windshield.
    Just my 2 cents but you might want to call the service center now and ask them what they're plan is to fix this etc and if they're going to replace the line and windshield ask them to order it now so that they can do it to all at one time vs breaking everything up.
  18. lloyds
    lloyds Member
    Bay Area
    Thanks much for the info. I'll keep you updated on this fix.
  19. darthvdr
    darthvdr Member
    los gatos, ca
    Was this fixed? My wife found a similar leak in the rear passenger side when she noticed her groceries wet.
  20. lloyds
    lloyds Member
    Bay Area
    Been pretty darn busy at work lately. So I got the car back. There was a bad seal, which caused the leak in the first place. They sealed it back up and were able to get the stain out of the liner, so they didn't need to get the liner replaced. Service overall was pretty good, but I am waiting to hear back from them regarding my laptop. My insurance carrier told me they would not cover any items that are caused by manufacturer defect, which in my situation is the case.
