whitex
Using 2 of these on my 2015 MS:Where did you order these from?
Amazon.com: Pilot Automotive IL-6461W-AM White 3-SMD LED Dome Light Bulb: Automotive
That depends on which car you have (pre-post refresh, X or S). You can find various installation positions in the pictures linked below (scroll down, there are a couple of Tesla installs there).I got two speeding tickets this year. Where are you going to install the laser blasters?
No error codes on my car and I've had them installed for months now. The only thing to remember is to turn the LED's towards the license plate when installing as the new light bulbs are not omnidirectional the like the original incandecents.I assume that when installed, they don't throw any error codes?
I connected directly to the positive power buss on the top of the 12V battery, it's then run through the "firewall" and routed to under the 17" screen.Hey Green, what did you connect the other end to, to supply the power?
(Can't go look at my car, since I don't have one yet. )
Which of the 3 options did you get and can you share some photos?
Weather mats and tire repair kit. The kit I will probably never use. But in emergency it does help. I also bought mats for the frunk, trunk, and under carriage storage area. Basically all weather mats everywhere.
I am looking to upgrade the stock LED lights in the trunk and frunk so I can get better light. The upgrade is a bit expensive and requires you pop open and remove the oem led. I might skip it for now or just build a battery powered led switch and use that when needed.
Definitely skip the roof shade because I found out it was not need.
Also I highly recommend wrapping your car. Or at least the front to avoid rock chip and such during the drive. This accessories can be expensive though.
yes, it is a cable to use public chargers in europe.What is this? Something different than the CHAdeMO adapter?
BBB4000 said: ↑
Thanks! Any idea roughly how much people are paying to get something like Xpel installed? I have a Pearl White MS on order. Is it necessary for white as well?
I installed Xpel on the entire front of the car (everything in front of the doors: bumper, entire hood, front fenders up to the door, rearview mirrors, support between the windshield and the window of the front door). I also covered the thresholds to all four doors and the back hatch. This cost $1800. I do not recommend coverage of half of the hood. Dirt will collect along the seam. When you cover the entire hood, the edge are curled underneath and are not visible.
The day after installation, a small number of tiny buckles appeared the edges of some extremely curved surfaces (such as the rearview mirrors). I contacted my installer. He came to my home and resolved the buckles at no charge.
The quality of the final result depends on the quality of the installer. Find the best, not the cheapest.
I did it myself. It is not top notch quality but from a distance, no one can tell the difference. And only when I point out the flaws do people realize them.Who did your wrap? I live in San Diego and am taking delivery March 9th.
Thank you,
Aaron
I have done clear film wraps before also. Take your time and watch the videos and you will be OK.I did it myself. It is not top notch quality but from a distance, no one can tell the difference. And only when I point out the flaws do people realize them.
It is not that difficult to do it yourself, especially if you can get someone else to help you with the work. The key is to swipe always 1/2 length to get rid of the water and bubble. I would check the dealers to see if they are willing to sell you sheets of xpels. There are tons of online videos to show you how properly install them.
