What are you guys using your 12 volt socket for?
Discussion in 'Model 3: Interior & Exterior' started by MarsOrBust, Dec 23, 2020.
  1. MarsOrBust
    MarsOrBust Member
    Kepler-22b
    Extra USB ports, fiber lighting, some other hardware or nothing at all.
  2. XLR82XS
    XLR82XS D M C
    SWFL | Vegas
    Nada. Thinking about a 12V plug-in cooler for road trips - then I'd use it.
  3. KenC
    KenC Active Member
    Maine
    I heat my steering wheel.
  4. drtimhill
    drtimhill Active Member
    Seattle
    Putting air in tires from time to time
  5. Ronbo
    Ronbo Member
    Los Angeles/Oxnard
    I also use it for my portable air compressor.
  6. Rockster
    Rockster Active Member
    McKinney, TX
    Dash cam, installed before it became a built-in feature.
  7. UncertainTimes
    To charge my 12V battery.
  8. amadiva
    amadiva Member
    Philadelphia
    Electric blanket
  9. RickW
    RickW Member
    Seattle
    Portable Vacuum Cleaner.
    I found the "THISWORX" brand to work best. It's available on Amazon.
    It fits perfectly in the trunk and has a very long cord so that you can vacuum the back.
    Suction is very good.
  10. 03DSG
    03DSG Active Member
    Ontario
    ditto
  11. t518
    t518 Member
    Los Angeles
    To Power Radar Detector :rolleyes:
  12. Tres_Azul
    Tres_Azul Member
    Arizona
    My music & dashcam USB hogs the other USB type-A port in fwd cubby, so... I use the 12v port in rear cubby for (2nd) iPhone charger & air compressor.
  13. elptxjc
    elptxjc Member
    El Paso, TX
    For a 1-Amp adapter to charge our 2 iPhones (1 cable, and a USB-A port in the back). But since I'll need that port to power my V1 for our upcoming long trip, will buy 2 USB-C charging cables to power our phones from the rear USB-C ports at the rear. The other USB-C ports are inside the front compartment, which we always have closed. And yes, guess we need to update our phones to charge them wirelessly on the provided 'pads' :).
  14. Ravire
    Ravire Member
    Orange County
    To power a tablet for CarPlay and ambient lighting
  15. MXLRplus
    MXLRplus Active Member
    Eastvale, CA
    Monitoring 12v battery voltage and fast charging phones.
  16. Fadiawesome
    Fadiawesome Member
    IDAHO
    dash and center console fiber lights
  17. shiftkenny
    shiftkenny Member
    San Diego
    What plug are you using. I hate that when i use a regular 12 plug plus the wire bends everything.
  18. MXLRplus
    Eastvale, CA
  19. AdamVIP
    AdamVIP Member
    I keep my phone on a wount in front of the steering wheel. I have a charger set up in the port to keep it topped off.
  20. XLR82XS
    XLR82XS D M C
    SWFL | Vegas
    That sucks.
