What do you think of roof rack?
Discussion in 'Hong Kong' started by pinguhk, Jan 26, 2015.
Tags:
  1. pinguhk
    pinguhk Member
    hong kong
    I saw this Tesla with a roof rack and like to know is this roof rack from Tesla and is it safe for the full glass top?
  2. Ringring
    Ringring New Member
    Hong Kong
    very safe.. not to worry!!
    this is perfectly safe. i saw at the US people put cargo on top. (glass top)
  3. jgs
    jgs Active Member
    Ann Arbor, Michigan
    Not only is it safe for the full glass top it's only possible with the full glass top. If you look carefully, you'll see the glass top has four recessed attachment points for the rack. These points aren't present on the plain top.
  4. pinguhk
    pinguhk Member
    hong kong
    IC that means if I what roof rack then need to have glass top
  5. Hd172
    Hd172 Member
    Pleasanton, ca
    I have the roof rack on my car. My only complaint with the whole system is that the rubber boots mar the paint a little. I'm cutting some bigger 3m film patches to go under the full boot. The kit comes with a couple strips but they don't work well.
  6. jgs
    jgs Active Member
    Ann Arbor, Michigan
    Correct. Per Tesla Gear Shop Model S Whispbar Roof Rack System, "The Roof Rack System is made for the Model S with the Panoramic Roof configuration only. It will not work with the solid roof configuration."
  7. paulwesterberg
    Madison, WI
    I have used a roof rack on my vehicles for years(mostly to haul bikes and sometimes kayaks or canoes).
    I have an S85D on order and I plan to install an eco hitch and plan to use hitch mounted racks or a mini-trailer to do the job.
    Hauling things on your roof is really bad for aerodynamics and will reduce your range when going highways speeds.
  8. jgs
    jgs Active Member
    Ann Arbor, Michigan
    You'd think so, wouldn't you? Some interesting findings in this review, though: Tesla Model S Roof Rack System (Whispbar) Review - TESLARATI.com "We concluded that the 1.26% increase in energy over the vehicle’s lifetime average is negligible and therefore it’s inconclusive that the change is a result of wind drag from the Tesla Model S roof rack system."
    It's not a controlled test, but still interesting. But, they didn't test the system with a load, just the bare rack. Most interesting would be testing a loaded rack against a loaded rear-mounted system such as you're considering, and one suspects that would have shown a greater difference -- although a rear-mounted rack will still significantly mess with your aerodynamics.
    I for one would be interested to hear how your eco hitch installation goes.
  9. DITB
    DITB Charged.hk co-founder
    Hong Kong
    Model X is apparently going to have some kind of rack to mount behind the car. Instead of sticking up into the air, hiding behind it. Would likely still increase drag, but a lot less than a top mounted traffic load.
  10. lx3h
    lx3h Ex-Charged.hk Tesla Owners Representative
    Hong Kong SAR China
    I know someone on our LINE group chat who has one. Seems perfectly fine for him.
  11. Lerxt
    Lerxt Member
    Hong Kong/Australia
    The roof rack is a common accessory. It wouldn't be available if it wasn't fully authorised and tested.
