stopcrazypp
BTU per mile is a direct measure of efficiency (a car with a lower BTU/mi is more efficient than one with a higher one)! And the link I gave already shows all the assumptions, including the assumption for pump to wheels. And it seems they are assuming both cars are large cars.Your numbers say nothing about efficiency. How can we know that the assumed vehicle energy requrements are the same for FCV and EV? Often you see that research institutions assume that EVs are small city cars while hydrogen FCVs are full-sized family cars. A larger vehicle will naturally use more energy per mile.
For pump to wheel it assumes:
HFCV = 2197 Btu/mi = 64.4kWh/100 mi = 52.3mpge
EV = 1357 Btu/mi = 39.8kWh/100mi = 84.7mpge
You have to click the link to the excel file to see the exact numbers (rather than just a graph/chart):
http://greet.es.anl.gov/files/greet1_2012_results
As you can see, the Clarity (mid-sized) gets 60mpge, F-Cell (small) gets 50mpge
http://www.fueleconomy.gov/feg/fcv_sbs.shtml
Model S (85kWh, large) gets 89mpge.
http://www.fueleconomy.gov/feg/evsbs.shtml
You can change the number for Hydrogen to the Clarity's 60mpge, and EVs will still be on top using the Model S number. To be really "fair" you would use the Leaf's (mid-size) 115mpge, but that would put hydrogen at an even greater disadvantage. And small cars actually don't really have a big efficiency advantage, as their aerodynamics give them a disadvantage in highway efficiency.
We'll see how much mpge the Toyota car gets pretty soon.
