1) energy (L), trips (R)
2) like brianman, I think it defaults to cabin temp but I've had it set to others before - basically I don't use it
3) map/nav (T), media (B)
When you're "tight" on range during a trip with Nav on (and thus occupying the left), where do you look to watchdog energy consumption?1. Energy(L), Trips (R)
2. Temp usually, fan if running w/o A/C
3. Nav/Media
I have my car for a little over a year, and I cannot figure out how those blasted things work. So, my display shows nothing. I have dicked around with those little spinning wheels three times and for the life of me they make absolutely no sense whatsoever. And the owner's manual is no help either.
In fact, I have no idea what all those buttons are for that are at the 9 and 3 positions on the steering wheel, either.
Just sayin'...
1. Trips (L) and Media (R)
2. Sunroof
3. (T) google maps (B) energy usage when I drive or backup camera when my wife drives
1) Left: Media, Right: Trips
2) Never use it, so it is in the "select the feature" mode, I think
3) Top: Camera, Bottom: Media / Nav
So far never seen the need to look at the energy graph.
OK stupid question, but I can't seem to find it in the owners manual. How do you change the dash display right and left portions ?
Thanks for the info, that worked great.Press and HOLD the scroll wheel on the respective side you want to change. When the menu pops up, scroll to the "app" you want showing up there and click the scroll wheel.
Now how do I change the fuel gauge in the center ?
It currently shows %remaining, but I see others are showing "rated miles" or "Projected miles"
Wow, that's beyond insane! I'm curious... being in Calgary, I'm assuming most of your driving is on the flatlands... highway speeds, city stop/go, or constants low speed highway driving? I could always squeeze out great mpg in my ICE, but my overall average is still a hair over 200 Wh/km. But I'm in a hilly part of the world and take advantage of pre-conditioning the car...
Also keep in mind that if you don't like or need the navigation directions on the left side pane of the dash you can still press and hold the left scroll wheel and go back to whatever else you might want while still navigating. You will still get little navigation popups when turns are required but you don't have to look at the navigation pane the whole time you are navigating. I find this useful when on long trips and I don't need the navigation information up on the left pane while traversing hundreds of miles of straight forward interstate.
Still, I'm intrigued to know more about your driving habits to see what I could do better?
Perhaps it's more about longer runs at moderate speeds. I'm either in the city, stop and go, or out on the highway doing 100 - 130 for long distance. And I do use the HVAC. I'm getting better about going easier off of the lights, but it's just so effortless! I managed 170 Wh/km on a 240 km highway run today at about an average of 105 km/h. HVAC was on (39 degrees with full sun is too much for me... ;-) )Just drive how the hand book tells you to, ive noticed when others are driving they are ALWAYS flooring the car and not even noticing it or going fast and slow, fast and slow.
When you accelerate, set off how the driving instructor tells you too (like in a corolla), just smooth, not slow not fast.
Going fast in Calgary i find is useless, there are way too many lights and the second you stop you loose every single second you gained from speeding.
i have range mode on and have HVAC always off (simply because its always a comfortable temp for me, im good if its 10C - 35C)
Calgary is all hills up and down, going to work i get around 103-106 Wh/km (like you see above)
going back home i get around ~170 Wh/km so it averages out to about 145-155Wh/km (depending on traffic)
the 182 Wh/km includes winter driving and all the test drives ive given out to experience the 0-60 of the vehicle
if i just went to work and back and didnt have to make any detours or pick anyone up. I can crack 148 Wh/km round trip reliably just by following the speed limit (nobody follows the limit in Calgary so sometimes its not possible)
It seems to me that quick off the start with electric doesn't incur as great an energy penalty as in an ICE though...
