Ok, I got a little carried away. Added a couple amp/volt meters, along with a KWH meter so I can see total of what the car uses.
Heh
That's a sweet setup. If you don't mind me asking, would you ballpark how much extra the extras ran you? TIA
I like it. How about some more details on your meters?Ok, I got a little carried away. Added a couple amp/volt meters, along with a KWH meter so I can see total of what the car uses.
Heh
Re the thread title-- HPWC is High Power Wall Connector, not Charger. The charger is in the car.
It cost me 420.00 for the watt hour meter, and 12.00 for the volt/amp meters. Both purchased from Amazon. I tried sending this info with links, but it doesn't seam to go through. I have one amp meter on the HPWC and one on the main feeding the Sub panel. Here is the info with out the links.
E-Mon D-Mon E10-3208100-JKIT Class 1000 1 or 2 Phase, 100A, 120/208-240 Volt kWh Electric SubMeter
DROK® Digital Current Voltage Multimeter AC 100-300V 100A Voltage Amperage Meter, AC Volt Amp Testing Gauge Power Monitor LCD Dual Display Voltage Measuring Current Sensing Resistors with Current Transformer CT
- - - Updated - - -
Thank you for correcting me on this. How can we change this in the title of the post?
Here is my compact setup.
Excellent... that's about what mine will end up having to look like when I relocate it...
Any tips on installation?
