Hello, all. First post here, although I've been following for awhile.
I want to move towards upgrading my current setup, and want to know what I should beware of and questions I should ask.
Right now I have a six year-old 6.84 kW roof-mounted solar (24 x 285w) system with a SolarEdge SE7600A 7600w inverter and SolarEdge P300 power optimizer
It's a multifamily dwelling, so the above supplies around 40% of annual electricity use
I have the room, and would like to add at least as many panels again as to reach 100% of future use, which will ultimately I hope through attrition include the replacement of 2-3 ICE vehicles (and some farm equipment) with electric. If I end up overbuilding a bit and routinely put some extra into the system, I'm not going to worry too much.
So, I'm thinking: inverter upgrade, add thirty or so rack-mounted panels @ 300+w each, two Powerwalls.
The current panels are on top of the garage, with the inverter inside. The Powerwalls could also go inside the (climate-controlled) garage, and the rack-mounted panels around fifty feet away.
What about this is impractical, what technical hurdles will I be looking at, and what questions should I be asking the contractor(s)?
Thanks
-scarecrow
Thanks
-scarecrow
