What exactly does "speed limit mode" do?
Discussion in 'Model S: User Interface' started by aikisteve, Jul 3, 2018.
  1. aikisteve
    aikisteve Member
    Belgium
    As of firmware update 2018.24.1 (and mobile app version 3.4.1) we now have a "speed limit mode" as a safety feature. So I made a short video about how it works and what exactly it does?
  2. gdh66
    gdh66 Member
    Portland
    Same as valet mode. Notice the "chill" above the speed indicator.
  3. aikisteve
    aikisteve Member
    Belgium
    Have you watched the video. I explain that, but there is a bit more to it than emulating valet mode
  4. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ Respect the mods stay on topic
    Probably on the couch
    Can you enable it remotely while someone is driving the car?
  5. ⚡️ELECTROMAN⚡️
    No you can't, so make sure you enable it before your kid flies off with your Tesla. My daughter didn't even notice it was enabled yesterday for the first time. Good sign she wasn't doing any launches.
  6. IsthataTesl.a?
    Arizona Territory
    I think if the car is in Park, you can enable it, so you can enable it during a trip, or while someone is in custody of the car, but not while they are actually driving.
  7. adomanim
    adomanim Member
    annaba
    Speed Limit Mode – This feature limits the acceleration of your vehicle and allows you to set a maximum speed limit between 50 mph and 90 mph. While your car is in Park, you can activate Speed Limit Mode by tapping Controls > Safety & Security on the touchscreen or by tapping CONTROLS on the mobile app. You must use the same 4-digit PIN to enable or disable Speed Limit Mode. A notification is sent to your mobile device is your vehicle approaches the set maximum speed. — In memory of Barrett Riley.”
  8. IsthataTesl.a?
    Arizona Territory
    Thanks for the info. Personally, I think a user selectable number would be better, or maybe 99MPH. Even though the highest "speed limit" sign might be 80 in the US and flow of traffic might be 75-85 in many places, it's important that the acceleration be there if needed in an emergency.
    I say this with "my friend" having received a criminal speeding ticket in Arizona, a Class 3 Misdemeanor.
    Speed limit mode would also work better with a city/highway or "over posted" setting to reduce the likelihood of someone going 99MPH in a area with a 45, or worse lower speed limit.
  9. Chaserr
    Chaserr Hyperactive Hyperdrive
    Logan
    The important part is Chill Mode. Barrett Riley was driving triple digit speeds in a 30 zone when he crashed into a house. Chill won't stop it makes it require a lot more room and removed the launch rush that caused those speeds.
  10. IsthataTesl.a?
    Arizona Territory
    It's important to realize that the margin for error diminishes greatly with increased speeds and speeds over the posted limits. The consequences for not realizing and being aware of this can be deadly.
  11. Galinette
    Galinette Member
    Nantes
    Too bad. In case the car is stolen, it would be fun limiting the speed to 30mph to help the police a little bit.
  12. adomanim
    adomanim Member
    annaba
  13. crocoyes4
    crocoyes4 New Member
    Nevada
    According to the update, this speed limiter feature will let you "limit vehicle speed and acceleration with speed limit mode" and that the maximum vehicle speed can be set between 50 to 90 mph. So if you're concerned about little Timmy Junior putting the pedal to metal but you don't want to go full Valet Mode on him, then this might be a good way to control the speeds without locking him out of the rest of the car's features, for example.
