Thanks, PV-EV. I'm kind of tempted to ask them to do the pin replacement first, just to prove that it really is the motor, but the pins were replaced (both the PEM and cable) back in 2015, so not that old. And there have been a few groups of 1146's in between, and even before when I look back in the logs. I don't recall if we messed with the pins since '15 (vague recollection of a "wiring change"). The only really quiet period was from 4/17 through 8/18, then they started up again.I’m pretty confident 1146/1144 errors are due to the electric to the fans being out of spec. This could be due to faulty connectors, faulty fan motor and even debris keeping the fan from turning freely. If the pins are indeed “perfect” then it will be interesting to see how you fair with a new fan. Personally, I prefer to do this repair myself as I have found the SC doesn’t pay attention to details but prefers to install new ($$$) parts until you run out of money or the problem goes away. Just my opinion. I am 3 years with no 1144/1146 errors after replacing the connector AND pins inside the PEM. Also I am on my same fan for 7 years after the working original was replaced with the upgraded fan. Good luck, keep us posted.
Yeah, considered it. Looked in there. Seems clean, but can't reach it (maybe with a stick?). How free should it be?Have you tried reaching inside the squirrel cage and spinning the fan by hand? (Car off, cool, not charging.) That would give you some idea of the condition of the bearings.
I would think very free as the fan on my 1.5 spins very easily and freely.Yeah, considered it. Looked in there. Seems clean, but can't reach it (maybe with a stick?). How free should it be?
I also figured that it'd be one of the obvious things the SC would test, since they had the car apart (or at least, powered off), and they made no mention of bearings being the issue. I recall a post somewhere about the motor's electrical bushings being a problem, so am thinking perhaps that's the root issue. Seems like a very expensive repair, if so... Worth asking them about, regardless.
Last couple of top-off charges occurred without 1146's, but the weather is cooler. I've got some errands to do early next week, so we'll see if there is a correlation.
Thanks for the info. In the back of my mind I was thinking the same thing, that the problems I have had have been a mix of both issues - connector and motor. That the trouble has gone away makes me think that my issue was actually due to the fan motor being stressed by that high temperature run home after the botched reassembly of the car. I can imagine that the motor brushes were burned by the experience, and over time they have readjusted or cleaned themselves and so now are acting properly. If so, then perhaps a new fan motor will in fact be needed, as it is probably about worn out. A connector with burned contacts is not going to get better with time and use.be asured, your problems are connectors plus fan. sorry to say so, but all SeC's i know would tell you either that the pins are ok or want to sell you a remanufactured pem, as they are not allowed to open and fix it (correct me if wrong !).
The past two Annual service events have left my car initially in worse shape than when it went in.
The 2.x can pull up a lot of dirt and leaves from the road. But if miles are few and your roads are clean it can be pushed off in my Humble opinion. The 1.5 is much better as the PEM fan is WELL off the ground. So with clean roads two years is just fine as I get very little dirt from cleanings.This is my fear as I prepare to bring #728 in for a (late) annual service. Everything is running great - still the consensus to get the annual service done?
Hi, I'm getting the same errors but I'm in Australia and a long way from anyone who look at it. I pretty keen to have a look at it myself but would greatly appreciate any advice, or instructions if there are any available. Part numbers for the connectors and the fan would also be great, particularly upgrades if available.I’m pretty confident 1146/1144 errors are due to the electric to the fans being out of spec. This could be due to faulty connectors, faulty fan motor and even debris keeping the fan from turning freely. If the pins are indeed “perfect” then it will be interesting to see how you fair with a new fan. Personally, I prefer to do this repair myself as I have found the SC doesn’t pay attention to details but prefers to install new ($$$) parts until you run out of money or the problem goes away. Just my opinion. I am 3 years with no 1144/1146 errors after replacing the connector AND pins inside the PEM. Also I am on my same fan for 7 years after the working original was replaced with the upgraded fan. Good luck, keep us posted.
