I was told all my Model S needs is windshield wiper fluid. I read somewhere that the gearbox has sealed in oil rated for 15 years. Are there other fluids that needs topping or replacing? Brake fluids? Battery cooling fluids? Anyone knows?
Are you sure about there being a brake fluid well in the frunk area? This car has pneumatic brakes - it's stopped by compressed air. The e-brake is electrically actuated. AFAIK there is no brake fluid involved at all.
To my knowledge the only two fluids in the car are washer fluid and a gear fluid similar to transmission fluid that is changed every 120k miles.
Umm... there is an air suspension option. But I'm pretty sure the Model S has standard hydraulic brakes. When I drove it, it didn't sound like a bus. There is of course an electric pump for the brake booster.Are you sure about there being a brake fluid well in the frunk area? This car has pneumatic brakes - it's stopped by compressed air. The e-brake is electrically actuated. AFAIK there is no brake fluid involved at all.
If you pop the top trim panel that covers the fuse boxes, you will see a standard hydraulic brake fluid reservoir marked with DOT 3, I believe. There is also a coolant fill bottle. As noted, the only cap visible without this panel removed is the windshield washer fluid.
Man, too much guessing going on here. The second set of calipers are electrically actuated and are used for the parking brake. Regen of course happens within the motor.There is an additional caliper on the rear wheels, which I'm guessing are for regen. Those may not be hydraulic.
Yeah, standard hydraulic brakes. You can see the brake fluid lines going into the calipers.
Be careful if you fill the fluids behind the panel. I think that in the owner's manual it says that if anyone other than Tesla employees do that it voids your warranty, if I am not mistaken.
Cheers.
It's illegal in the US, too. The Magnuson Moss Act prohibits "tie-in sales provisions". If someone properly puts factory equivalent brake fluid into their car and Tesla tells them their warranty is invalid, it's a lawsuit waiting to happen.I'm presuming the Australian supplement will negate that - it's illegal to restrict warranty in Australia on the basis of using a qualified third party mechanic for standard services (especially fluids). I am surprised they get away with it in the US and Canada?
