What have you done to your Roadster today (or lately)...
Discussion in 'Roadster 2008-2012' started by TOBASH, May 26, 2020.
  1. GJVR
    GJVR Member
    Amsterdam
    I think black are the best for glacier blue.
    But I am considering orange for my winter set. To add a little Gulf Racing effect. :)
  2. CAR3NUT
    CAR3NUT Supporting Member
    Tucson, AZ
    Finally got around to a few mod's:
    1. With the help of @slcasner (steve did most of the work) was able to add the third brake light mod. Really is a nice feature to have :).
    2. While I had the third brake light out I changed out the dome light to a Super Bright LED 194-WHP6, what a difference now you can see inside the car :).
    3. Changed out the OEM radio to a Pioneer AVH-3500 NEX. What a difference in the sound :).
    4. The last thing I did was add a "Roadster" badge to the rear of the car. :) Took a Roadster Sport badge and removed the Sport portion.
  3. rudholm
    rudholm Member
    Los Angeles, CA
    Does the screen collide with the windshield wiper stalk when it extends/retracts?
  4. da2ny
    da2ny 2010 Roadster Sport Twilight Blue #913
    Beverly Hills, CA
    I installed a Pioneer AVH-3500 NEX in my Roadster and I used my trusty Dreml cutoff wheel to remove about 3/16" from the outer end of the stalk and then glued the end cap back onto the end. No clearance problems. Can't see any surgical scars.
  5. jason.tv
    jason.tv Member
    Florida
    Woohoo!! nice, would love to see some videos how it functions.
    Here are some of my installs,
    stereo finished - video
    splash screen - video
  6. CAR3NUT
    Tucson, AZ
    Since I installed the Pioneer radio I tried retracting the screen only once and per other comments on other threads regarding this upgrade if you pull back on the stalk while the screen is either extending or retracting it clears without any problems. I have left the screen extended, closed off the center vents (not even an issue here in AZ last summer with 115 degree heat) the cabin is so small the side vents provide sufficient cooling to make the car comfortable to drive.
  7. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    Carbon Fiber vent inserts. Small, expensive, not easy to install - but makes a big visual difference every time you go to get into the vehicle since you can't look at the door open button without seeing them.
  8. Lou B
    Lou B Member
    Carlisle, MA
    The Carbon Fiber vents look great ! Did you install them your self ? I want to upgrade
    Mine also. How long did the install take? Did you install from the wheel wells?
    Thank you,
    Lou
  9. smorgasbord
    SF Bay Area
    A fellow Roadster owner helped me install them. Yes, from the wheel wells. It's actually not that difficult. First, note that the studs are epoxied to the underside of the car body, so it's actually really easy to torque them off, even with hand tools. It's a 10mm size. Go slow and easy. I ripped once off. Repaired it with the epoxy gel that takes an hour or so to harden (sets in 10 minutes, maybe the longest 10 minutes of my life).
    I'd start with the driver's side - it's easy to remove the subwoofer chamber (one screw) then you have pretty easy access to the three nuts. Leave the far nut on - the vent hole there is slotted so it can slide in/out. Having a helper to hold the new vent in place while you retighten the nuts is helpful. Just tighten until the nuts touch - then have the helper try to wiggle the vent and tighten whatever seems loose.
    It's a bit tighter on the passenger side, but do-able. I've read you can alternatively remove the rear deck, but don't know how to do that. Anyway, took us a few hours, but if you know what you're doing I could see getting them done in 45 minutes.
  10. Lou B
    Lou B Member
    Carlisle, MA
    Thank you for the tutorial, always nice to learn from someone that has done it.
    Thank you.
