What height are you riding in the MX
Discussion in 'Model X: Driving Dynamics' started by Socalcommuter, Jan 31, 2017.
  1. Socalcommuter
    Socalcommuter Member
    Los Angeles
    Since buying my car and reading the forums I have left my car ride at standard. Although I'm scared of premature tire wear, it would be nice to have a little better handling on the turns and ramp curves.
    Just curious is other MX drivers are being conservative as well.
  2. beths11
    beths11 THE LONG RANGER
    Molalla, OR
    Standard, and "lower at faster speeds" = "never" To be fair...I didn't want SAS, but I had no choice. I have read "anything other than standard causes premature tire wear".
  3. McManX
    McManX Member
    Silicon Valley, CA
    Standard and drop to low at 70mph
  4. muleferg
    muleferg Active Member
    North Wilkesboro, NC
  5. DonD
    DonD Member
    Clermont, FL
    My Model X suspension is set to Standard, and changes to Low at 50mph. With 10,000 miles so far on the original equipment tires the tread depth still measures evenly inside to outside, and is consistent on all four tires. I would estimate perhaps 25% of my mileage is driven at 50mph or greater.
  6. Ormond
    Ormond Member
    I'm set at standard and drop at 70 mph. I raise up for some driveways. I like to drop to extra low for washing the windshield.
  7. ptsagcy
    ptsagcy Member
    NJ
    20" Conti-Silents. 15,000 miles, 7/32 left on all 4 - even wear. Standard around town. Low set to 55 mph.
  8. bushburner
    bushburner Member
    new orleans, la
    standard, my wife drives it and i'm scared she's going to scrape it.
  9. jeffaa
    jeffaa Member
    United States
    For those who set it to LOW at a certain speed, it would be nice to know what percentage of your miles driven are at those speeds.
    If I set mine to low at 60mph but do mostly city driving, then I'm not going to see much inner tread wear compared to someone with the same settings who does mostly highway driving.
  10. Solarman004
    Solarman004 Member
    Colorado
    Standard, and drop to Low at 75 mph. I'm in low probably less than 5 % of my driving.
    I noticed that after triggering Low at 75 mph, it won't rise to Standard until I decelerate below 45 mph.
  11. bushburner
    bushburner Member
    new orleans, la
    I'm not worried about tire wear as much as ride quality and suspension wear.
  12. Gwgan
    Gwgan Almost a wagon
    Maine
    That was my setting until this last service visit when they said there was no fix in sight for the front vibration on acceleration (yet) and they recommended Low. There are places, like my driveway, that automatically go High. Also some roads around here are too lumpy for Low so now I just bump up manually as needed.
    Contis wore well at that original setting, the Michelins had very asymmetric and heavy Right rear inner wear. We'll see how the winter Pirellis fare with mostly Low.
  13. Paul Carter
    Paul Carter Active Member
    Vancouver, BC
    There's a thread on that already and I believe setting to low will cause some premature wear.
    Rear Tire Wear on XP90D
  14. FarmerDave
    FarmerDave Supporting Member
    Martinsburg, PA
    Same here, but recently switched to Bridgestone Blizzaks for the winter.
  15. Socalcommuter
    Los Angeles
    Changed my setting today to low over 60 mph. Maybe I'm imagining but the ride feels more sporty and nice. I like it. I pray I won't have worn treads though.
  16. 3s-a-charm
    3s-a-charm Active Member
    Calgary, Canada
    I think the tire wear on low settings is accentuated with lower profile tires (22" wheels vs 20"). My P85D with 21" wheels was brutal when on low setting eating through tires (wearing on the inner portion to the bead) in no time.
    The 20's are likely more forgiving on low settings.
  17. Socalcommuter
    Los Angeles
    Damn. I have 22s
  18. goneskiian
    goneskiian Active Member
    Bellevue WA
    Just to be clear, the original poster in that thread had theirs set at "Very Low" not "Low".
    That being said I keep mine in LOW 100% of the time. I don't have many miles so far (only about 6000) and Tesla swapped out my original rear tires due to not being able to get them to balance correctly and then I put winter wheels and tires on in December. Long story short, I'm not seeing any excessive tire wear but that's not surprising as I just don't have many miles on ONE set of tires.
    I am aware that my driving it in LOW all the time may cause wear but I'm OK with that.
    Cheers!
  19. 3s-a-charm
    Calgary, Canada
    So you have to manually change it to Low every time you get in the car? It became so onerous to me that I just accepted "standard" unless I wanted to look like a gangsta! ;)
  20. Gwgan
    Maine
    No, you can set the “speed” to auto-lower to Always (but that’s Low, not Very Low"
