What is a BSM Fault? What is going bad?
Discussion in 'Roadster 2008-2012' started by TOBASH, May 1, 2020.
  1. TOBASH
    TOBASH Supporting Member
    Rockaway Beach, New York
    #1 TOBASH, May 1, 2020
    OVMS has paid for itself...
    I was wondering why I was in storage mode BUT the charge fell to 83%. Roadster was plugged in using 14 gauge extension cord and 110 Volt Roadster charger with GSM delete.
    It is raining and about 60 degrees
    OVMS was not allowing me to turn on charge or swap charging modes.
    So I went to car and it said BSM Fault, BSM BEFORE CHARGING Fault, and another BSM fault.
    I tried reset by opening and closing door 10 times and still would not charge.
    I placed key in ignition and put car in drive and it gave me a "keep foot on brake" error. I removed key and re-inserted and car went into drive and then I was able to charge without fault with 110 Volt hook-up.
    Now I am currently charging.
    I went into the service screen and bricks are OK and charges are OK.
    So, what happened and what is potentially going bad?
    Thanks,
    T
  2. TOBASH
    wiztecki had this issue years ago.
    I may have previously had it and it was supposedly fixed IIRC
  3. IslandRoadster
    IslandRoadster Red Roadster #609!
    Bainbridge Island, WA
    Did you punish it?
    Oh! You said BSM fault!
    • Funny x 2
  4. X.l.r.8
    X.l.r.8 Supporting Member
    Toronto/Miami
    It’s easier to show the corresponding codes like 287. That will point to the fault a lot quicker
  5. TOBASH
    My safe word is “stay on topic”
  6. DeedWest
    DeedWest 2008 VP & 2011 2.5 Sport
    Dallas, TX
    Did you get the ID number on the bottom of the error message? Sounds similar to something I had a few years ago, only my car wouldn’t charge or start. It was the inferior 400V controller and a $1566 replacement.
    • Informative x 2
  7. slcasner
    slcasner Active Member
    Sunnyvale, CA
    Setting aside the topic of BSM fault for a moment, I was wondering about the above part of your post. I assume when you said "GSM delete" you were talking about having replaced the GFCI plug with a normal one and therefore that power should have been reaching the car. Are you saying that you had set the car to charge in storage mode and is your question why did it not change when the charge level was 83%? What I have observed with storage mode on my car is that it won't charge until the level gets below 50%.
  8. IslandRoadster
    I had my vehicle plugged in in Storage Mode with a Henry Sharp Can and a Tesla wall connector. I witnessed it come on at one point, nonetheless, it still was draining the battery and not in charge-keeping mode. Not sure why that was. When I checked it, I was down to 15 miles and it was well above that when I plugged it in several days prior and put it in storage mode. So like @TOBASH, I had my battery drained while in storage mode too.
  9. TOBASH
    BSM Faults 283 and 287
  10. X.l.r.8
    Toronto/Miami
    The easiest way and possibly the most expensive is go to the SC and they have an emulator, it won't say exactly what but they go through the components that trigger that alert. Usually the heater or 400v converter. If its the converter then @jason.tv has an excellent answer to replacement. Basically a HV component is shorting somewhere, mine was the HVAC, there is a drain at the bottom of the condenser that had become blocked and the element was sitting under 2 inches of water. Although was not the actual problem. Does both your heat and AC work? also my SC said they would lend me the emulator to charge the car if it faults again and fails to charge. I would ask to make sure the local SC has one.
    Powertrain Error 287
  11. jason.tv
    jason.tv Member
    Florida
    he has me confused with someone else I think; I don't know anything about a bsm or hvac fix. Sorry
  12. X.l.r.8
    Toronto/Miami
    My only excuse is lack of oxygen due to these damn masks. Jason is correct, I totally misremembered, its EV Mark on the facebook page that has the details on the upgraded 400V controller. Jason has the ultra clean one with carbon fiber goodies.
  13. TOBASH
    No no no. Jason has the Golden Fleece and was with the Argonauts
  14. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    Then EV Mark is me? o_O
  15. X.l.r.8
    Toronto/Miami
  16. mpt
    mpt Electrics are back
    Warren, New Jersey, United States
    Battery Safety Monitor is a popular fault, it's usually damp in the cabin heater causing great fear in the high voltage system monitors. If you can, wheel it out into the sun to warm through or, if you can, turn on the blower fan or heater and chances are it'll clear. If not, come back the following day and try again. If it still persists, then it might be a deeper issue like a blocked drain but, I think we've all had this at least once or twice, well, those that don't live in California anyway.
    • Informative x 4
  17. DeedWest
    Dallas, TX
    I second trying what @mpt mentioned above. If that doesn’t fix it, I would ask for a 400V controller replacement from your service center. It’s less than $1600 (both parts and labor) and should fix the issue.
    A local owner just had the same issue occur, and had his controller replaced today, ironically, as well.
  18. Perrin21
    Perrin21 Member
    uk
    #18 Perrin21, Jul 23, 2020
    It sounds like the 400V controller is dead. Look under the front Bonnet/hood and see if the red light is on on the controller. If its out, its dead. I wouldn't recommend buying another Eberspacher controller as the quality is garbage and they fail regularly. You can contact me on facebook messenger (EVMark) for the details of the company that supplies a much better quality board swap upgraded version. The new one is far superior to the Eberspacher and doesn't prevent the car from charging or starting in the event of a failure. Its a major reliability upgrade for the roadster. Its also cheaper than the Eberspacher so its a win win. Tesla can't help with this, its not available to them (they will sell you another Eberspacher). Its literally a 5 minute novice install, 3 bolts, its at the top and easy to remove. You send it off and the board is replaced with a new upgrade version, then its sent back for you to refit in 5 minutes. Job done. Note... Im not affiliated with the company, im not the company and i am not selling it myself. I found them and sent my own controller to them for replacement and its been an excellent find.
    On Facebook Messenger im EVMark
    • Informative x 3
  19. Perrin21
    Perrin21 Member
    uk
    or you can try this to get your car charging or started. I haven't tried it myself but let me know how you get on. As always, try at your own risk. Lark20200111-140558.jpeg
  20. jason.tv
    jason.tv Member
    Florida
    really curious what happened here with his car. I did send my controller off to Switzerland to get upgraded.
