What is a "panic event"? [in sentry mode]
Discussion in 'Model 3' started by Seth2020, Dec 9, 2020.
Tags:
  1. Seth2020
    Seth2020 Member
    Seattle, WA
    SENTRY MODE IMPROVEMENTS
    Sentry Mode footage of the last panic event will now be saved to onboard memory. To view or save this clip, plug in a USB device, launch the Dashcam Viewer, and tap the save icon on the bottom right corner of the screen. ​
    What is a "panic event". Manual makes no mention of it.
    Is any Sentry Mode event a panic event, or only certain types?
  2. chrstna4
    chrstna4 Member
    Seattle
    I was guessing it might be a sudden braking event. Or maybe it’s for people that don’t have a USB device always in the car (or it got dislodged) so people can access something they wanted to record with a honk or hitting the dashcam button. Just guessing, though.
  3. RedModel3
    RedModel3 Member
    United States
    Sentry, the security system, is not to be confused with the dashcam. Braking and record with honk are dashcam functions.
  4. JulienW
    JulienW Active Member
    Atlanta
    Likely a glass break or a G-force event like someone jacks the car.
    Use a SSD or quality flash drive and no need to worry about Tesla saving Dashcam or Sentry Mode events.
  5. Marius A
    Marius A Member
    NORWAY
    Except if the person who breaks the glass takes storage device with them.
    That's probably the biggest reason for this change.
  6. robinj27
    robinj27 New Member
    Another reason was failure to copy to hard drive in the event of a crash. Lots of cases where after a crash the drive either got damaged and didn't save the most recent event. But yeah also the drive removal after a break in (not many reported cases of that unless the theif knew of it).
  7. Knightshade
    Knightshade Well-Known Member
    NC
    The most obvious answer is "alarm goes off"
    Sentry has 3 modes (well, 4 if you count "off" as a mode)
    1. On. Sentry is just waiting for something to happen, not doing anything active at all.
    2. Alert- Sentry flashes the lights, displays the you are being recorded bit, and moves the last 10 minutes of dashcam footage to the sentry saved folder.
    3. Alarm- Car alarm goes off, sentry blares classical music, sends an alert to your phone, etc.
    • Informative x 3
  8. DaveG_NJ
    DaveG_NJ Member
    NJ
    You're kidding, right? It doesn't really do that, does it?
  9. Knightshade
    NC
  10. jjrandorin
    jjrandorin Moderator, Model 3, Tesla Energy Forums
    Riverside Co. CA
    I know @Knightshade answered, but yes, it absolutely does play loud classical music. Kind of a cool idea, actually. People are trained to tune out a standard alarm sound.
  11. pilotSteve
    pilotSteve Active Member
    Prescott Az
  12. katbc
    katbc Member
    British Columbia
    I think the new 2021 model 3's come with hard drives now that are in the glovebox and there's a pin to the glove box (they are meant to be incredibly hard to break into), so that's cool.
  13. katbc
    katbc Member
    British Columbia
    I was under the impression that a significant sentry event (perhaps now called panic event) is one that is enough to set the alarm off. So basically what @Knightshade said.
  14. Marius A
    Marius A Member
    NORWAY
    It's not hard to break into the glovebox, it can be pried open with a screwdriver.
    But AFAIK a burglar will most likely break the glass and grab anything visible. It's too risky spending time prying open things and trying to dive into the trunk.
  15. bcpm3p
    bcpm3p Member
    cali
    How do you view this?
    And where is the save icon on the bottom right corner of the screen. ? I dont see it?
  16. Seth2020
    Seth2020 Member
    Seattle, WA
  17. Optics
    Optics New Member
    Southern Califonia
    I saw this in my Sentry videos list (see pics). My daughter set off the alarm on the car. The video can be saved to USB, but not deleted.
