hi jj
one contradiction just entered my mind - you said:
> What you have is a partial home backup, but your AC is running through a power line that the tesla gateway can see, and provide power for when the grid is on.
so the battery provides power for the non critical loads via the measuring device when the grid is operating.
however you also said:
> What you are describing is the type of battery backup system where all power is served through the battery backup system and that system is then re filled from other sources. Thats not how powerwalls (or other home batteries) work.
so that says the critical loads are NOT powered by the battery...
so the battery powers non-critical loads and does not power critical loads when the grid is running - why the difference? doesn't the opposite seem more logical? why should it ever give battery power to non-critical loads?
Still seems like a wiring error to me.
thanks!
No, the battery powers both critical and non critical loads when the grid is up. There is no "wiring error" in your system using battery power to power all loads when the grid is up.
You were talking about "100% clean energy" and that isnt what happens. The system is not designed to run "ALL POWER' through the batteries. There is a difference in running all power through the batteries, and the batteries being able to provide power to all loads. A data center or hospital (something that can not tolerate even a little bit of switch over time to battery backup) will be setup in such a way as all power, at all times comes from the batteries, and the batteries are re filled from "sources".
Our home systems are not setup that way, and that doesnt have anything to do with the fact that the battery is setup to power loads.
An analogy would be if I was standing with you and your family, and said "I can give you some muffins for your family", I could hand you, your significant other, and any children you have each a muffin, and I would have given you all muffins.
Or, If you said "no, you will give ME all the muffins and I will hand them to my family", in this case I hand you the muffins and then you hand them to your family. In both cases they end up with the muffins, but in one case I gave them out myself (to all the loads), in the other case I handed them all to you, and you handed them out (to all the loads). In both cases all the loads got muffins.
You keep saying its mis wired, and I am telling you its not mis wired, its designed to operate that way. "Mis wired" means "wrong" and its not wrong, you just dont want it that way for <reasons> and thats up to you but its not "wrong".
In any case, I am obviously failing at explaining this, so I will again just wish you good luck with it, and encourage you to continue to find out from your installer if your specific install can be setup to remove the AC since it appears that is what you want.
