Wol747
Ah....Yes, I had to do the same so think it was a server issue...
I've read a lot of threads on this sort of thing Things to try:after a successful night sleeping I woke it up in the telsa app to check the range was ok (it was) and now its gone back to 1 minute sleeps
1 Reboot the car - can't remember if you've done this - 2 buttons and brake pedal.
2 Go into the app and then come out again. Sometimes this forces a sleep.
3 Force close the app
4 Reset your password - only takes a couple of minutes although I think you need to re-add your phone as a key.
5 Reinstall the Tesla app
These are all things that others have reported to fix their car not sleeping properly. Did you tell us what software version you had?
And software version?done everything except (5). I did a few things together when it did slee - updated Teslafi to wait longer, went for a drive, and turned off WiFi and cabin overheat protection
6/ Wait until something changes on the Tesla side @Blokie and me had something similar and it just went away. Seemed to improve with 2021.4.12 thoughdone everything except (5). I did a few things together when it did slee - updated Teslafi to wait longer, went for a drive, and turned off WiFi and cabin overheat protection
Chilly has the temp set at 25C?
Might be worth raising a service request with Tesla if it's been this way since you got it. Certainly not normal behaviour. They'll ask you to change your password again though...Its the only software mine came with so maybe a refresh will help. Ill just keep refreshing and sighing at the seeming randomness..
Don;t forget the number on the app is available battery. When it gets cold some of the battery isn't available. I charged last night to 80% and when I went to drive this morning the app *said* 76% but when I looked closer there was a little blue bar (showing charge which would be available when the batttery warmed up) which went up to the 80% mark.
My phone stays Bluetooth connected throughout the house, it has never stopped my car sleeping and since the last update the car doesn't even loose 1% a day. Even before that update, it was 1-2% a day maximum. I never force close the app. The car can sleep even with a Bluetooth connection.
As above, you shouldn't need to turn off bluetooth in normal use.I’ll turn off bluetooth to see if that helps but I want the phone to unlock the car so this is only for debugging
edit: before I could do that I checked the widget which reports it sleeping. So maybe the USB thumbdrive in the glovebox doing something weird? Or just unlocking/locking the car?
