Why? You can add basic Autopilot to a car that doesn't have it. I don't know the current cost, but someone else can probably tell us.Very helpful -- thank you! I guess I will be cancelling my order.
Very handy guide. BTW, these cars don't have blind spot monitoring. Not really anyway...
i do cause i experienced it several times.
I see, so if it doesn't cause an accident, it is reliable ?Really? How many car accidents, specifically, has it caused for you?
What I'm saying, I can't count the numbers of time where I put my turn indicator with the intent to change lane, a car is coming behind me and the car is not not warning me. Sometimes it does, sometime it doesn't. Of course I am not getting hit because I checked above my shoulder before changing lane.If the intent of the system is to reduce accidents, and you can't cite examples of it failing in that intent, then it seems to be doing its job.
Teslas accident rate in general is vastly lower than other common brands.
The thing is, most of the fancy systems of the car are not reliable.
The system which won't let you drift out of lane, I keep it off since the few times I used it, it was not working properly. The anti collision system : it usually beeps after you passed the obstacle. The wipers : don't start me on this one.
The connection to the car when you try to start charging when your car is at the airport for instance, it is a 50/50 chance.
Also, the number of times you have to open the back door of the car before you can actually open the front door !
The screen will reboot during your drive with no reason, and no I didn't touch the scrolling button.
And I won't mention the AP or FSD since I didn't buy it but obviously, a lot of folks on this forum have issues.
Yes, I had the mobile service checks the connection issue several times and no joy.
Now, if you had 0 of those issues it is a miracle or hard to believe.
Obviously lots of folks experimented those issues as you can read on this forum.
And yes, the simple light on the mirror I used before is a lot more reliable.
For the stat, I am not sure where you're getting your numbers from. Hopefully they are accurate.
