MikeBur
ManualPilot
I went from 3 buckets (2 rinse buckets for dual stage rinse) back to 0 rinse buckets. Sounds crazy right? Well not if you never re-use the microfiber mitt in the first place. How do you do that? I have a single 5 gal bucket with 14 chemical guys microfiber mitts in about 2 gallons of soapy water. I use each microfiber mitt once. One side gets one part of a panel. Then I turn it over and do another part of a panel, and then I toss it in the dirty pile bucket. I'd say rinse and repeat but there's no rinsing
Of course prior to a mitt even touching the paint, I've pressure washed the car once, then I use the low pressure nozzle and chemical injector to coat the car in a layer of car wash. I then let that sit for 10 minutes...never in the sun. Next I pressure wash that off. By the time a mitt even touches the paint, there's nothing visible left.
You'd think it uses a lot of water but the entire wash uses only about 7 gallons of water. The key is low volume high pressure that is NOT directed. i.e. I use a spinning rotary nozzle.
Same here, only DI water, Karcher (low) pressure and a Tornador foam gun using distilled water premixed with wash. I find the foam gun better than using the pressure gun and siphoned mixture. Too diluted and doesn't cling as well. 90 PSI compressed air driving the foam gun I found ideal.
Many microfiber mitts as well.
No shade though. Used to erect a giant tarp over the driveway. Got old, quick. Haven't done that in almost 10 years
I bow to your superior OCD cleaning techniques ;-)
Mine is pressure washer, foam cannon, 2 buckets and low pressure, rinse through no-spot water filter. Plus wheels / wheel arches. Griot's and chemical guys sourced for most
It has annoyed me a lot how wet it's been around here recently though. It's clean for less than a day usually :-(
