Only reason I stopped AP was to make a turn. It was rock solid. 8.0 AP1
And zero nags (hands on steering wheel)?On Saturday i made a trip from Vegas to LA and back /same day/. On the freeway/I-15/ i was mostly on AP /AP1/. Truned it off only in construction areas since it tends to drive very close to comcrete barriers and one imstance when I was cut off most of the way no problems.
You didn't mention "hands on wheel" in your original post. I thought you meant with no hands...And zero nags (hands on steering wheel)?
Ah! Yes I meant without hands on the wheel. Also the speed going above the 5+ speed limit limit.You didn't mention "hands on wheel" in your original post. I thought you meant with no hands...
I haven't had a nag in 6 months with hand on the wheel. I don't even look anymore to see if there is a nag, It's all in how you hold the wheel.
Yeah, but you can probably substitute some other words for "nag" in that sentence...I haven't had a nag since I got divorced.
If you're "holding" the wheel, in what way are you not effectively steering? Is holding it in that magic "right" way really much less tiring than simply steering yourself? I find that significantly more than merely hands "on" the wheel is required to avoid nags -- when it feels like nagging. Otoh, there are other circumstances -- such as long, straight interstate -- where it can easily go multiple minutes without nagging with my hands entirely off the wheel.It's all in how you hold the wheel.
It isn't ideal, I agree.If you're "holding" the wheel, in what way are you not effectively steering? Is holding it in that magic "right" way really much less tiring than simply steering yourself? I find that significantly more than merely hands "on" the wheel is required to avoid nags -- when it feels like nagging. Otoh, there are other circumstances -- such as long, straight interstate -- where it can easily go multiple minutes without nagging with my hands entirely off the wheel.
That limit only applies to undivided or non-limited access streets. On highways, there has never been a limit.What about the speed limit part? I thought it was suppose to only allow 5+ mph over speed limit for AP.. it allowed me any speed up to 90.
I did not know that, but also this was an undivided street. I have video of speed limit 40 and AP set to 70 (for example)That limit only applies to undivided or non-limited access streets. On highways, there has never been a limit.
