Knightshade
Question for you, are you saying that if *any* human driver is able to successfully navigate a particular situation, then the level 5 must also be able to navigate it?
Typically the law uses a reasonable person standard for such judgements.
So even if you're SUPER AWESOME at driving through white-out snow conditions, the SAE standard doesn't require L5 to do so (it even cites that as an example of something the typical driver is not expected to handle).
But "fairgrounds parking lot where hundreds, or thousands, of human drivers drive just fine every week" would certainly fall under a reasonable person standard as something a driver is expected to be capable of handling.
And so would an L5 system.
If not, do you think the sae definitions defines in which conditions specifically? Also if not, then who will ever define these conditions specifically or will be be struck forever debating what situation is actually "appropriate" for level 5 vs not?
In the sae definitions, it says *a* driver and not *any* driver. I think this is on purpose. If for any reason, *a* driver decides it's not manageable for them, then this driver isn't required to navigate it. In the same way, the level 5 can decide not to navigate a particular situation because for example, it can't see any lines or sees too much water in the road.
Yeah, no.
Again they SPECIFICALLY say temporary conditions that would prevent a human driver are ok to also prevent an L5 system--- in both cases the human and the L5 could pull over and wait for conditions to get better.
Waiting lets the snow storm pass, or the water recede.
it won't ever fix "Car can't figure out the parking lot- but humans can" though.
