What is Tesla's current range of motors?
Discussion in 'Model S' started by thegruf, Apr 8, 2015.
Tags:
  1. thegruf
    thegruf Active Member
    UK
    The models are (should be anyway) a mix of relatively few options.
    So what is going on?
    Now with the range update we have P85D
    470hp rear
    221hp front
    S85D
    211hp front
    211hp rear
    S85
    362hp rear?
    S70D
    329hp
    front?
    rear?
  2. Kbsilver
    Kbsilver Member
    Central NJ
    #2 Kbsilver, Apr 8, 2015
    I believe there are just 2 different motor combinations. The larger (original) motor (the 300+ hp variants) and the new smaller one (the 188-221 HP varients) which may have 2 different gearboxes for the front or rear applications. The differences in HP for the large or small motor is nothing more than differences in the inverter, or maybe as simple as how they are programmed.
  3. thegruf
    UK
    So if there are only the two motors then
    The 470 hp motor only provides 363hp in the S85
    The 221hp motor is derated by 10hp on the S85D to 211hp (really? - I'm thinking a spelling mistake here and really it is 221 not 211 - or vice versa of course)
    and in the S70D the two 221hp motors are derated to 165hp each?
    Of course the inverters and battery pack also have a role
    but the P86D/S85S and S85 all have the same pack, so same voltage
    The reduction from 221hp to 165hp in the S70D could indicatethat the S70 battery pack is indeed a lower voltage
  4. Thud
    Thud Member
    Atlanta
    These days I suspect there are only two motors: the big one and the small one. The HP variances in both motors are due to software and/or battery voltage. Somebody should do a teardown and see if there's really a difference between the 363hp and 470hp motors. :)
  5. TheDane
    TheDane Member
    Denmark
    Then I hope they will unlock a few more HP's in the S85 version, so it can get up to P85 level :)
  6. shawk
    shawk Member
    NYC
    Tesla builds or built these motors as well:
    Tesla / Toyota RAV4
    115 kW (154 hp), with peak torque in normal mode of 296 N·m (220 ft·lb / peak torque in sport mode of 370 N·m (270 ft·lb).
    Tesla / Mercedes A & B class
    100 kW (134 hp) 310 N·m (229 lb·ft)
  7. biciklanto
    biciklanto Member
    Germany
    Tesla's German site would seem to indicate that there are four motor capacities currently being produced: 224 PS (221 HP), 261 PS (257 HP), 385 PS (380 HP), and 476 PS (469 HP).
    The breakdown looks like this:
    • 224 PS: front motor on the P85D
    • 261 PS: all motors on the 70D and 85D
    • 385 PS: motor on the S85
    • 476 PS: rear motor on the P85D
