ZooSean
ZOO
Fcxk that’s going to be expensive supporting a mid level car. Very sad.
I decided to upgrade while I purchased my leaf. Part of the reason is my panel built 25 yrs ago, need to be maintained anyway for safety.
The 200Amp is not EVIP requirements, and I never said that. I said that you need 200Amp service for getting the certificate based on normal electricity usage situation here in Canada. You can say that I don’t have a dryer, I uses gas cooking and I don’t have air con. In that case you could be certified with 100Amp. If you have two of above, you need 200Amp to be certified.
That’s incorrect information. Everyone’s home electrical use is different. As mentioned above one needs a load calculation done first. Once that’s done you can add a circuit limited in amps by the load calculation. You can still have electrical appliances AND a car charging circuit that will pass inspection on a 100 amp circuit. It may just be limited to less than the max amps the car can accept.
So anyone with an electric stove and AC needs to upgrade to 200A to have the inspection pass?The 200Amp is not EVIP requirements, and I never said that. I said that you need 200Amp service for getting the certificate based on normal electricity usage situation here in Canada. You can say that I don’t have a dryer, I uses gas cooking and I don’t have air con. In that case you could be certified with 100Amp. If you have two of above, you need 200Amp to be certified.
I think majority of houses have 100 amps, no need to upgrade to 100A. My house is 30 years old and I have 100 amps service. I never upgraded my service, and got my rebate twice. Though my stove is gas, dryer is still electric.So anyone with an electric stove and AC needs to upgrade to 200A to have the inspection pass?
Any owners in here that have a stove and AC that didn’t upgrade to 100A?
We used The Electrical Works Ltd., Mississauga electricians
They are a Tesla recommended installer.
Like I stated earlier and other have too, a load calculation will determine what needs to be done and at what setting the charger is set to.
Its not just stove and dryer or AC, it's also finished basements and so on. Every house and scenario is different. Bigger house more plugs, more lights etc....
Have electrician come in and they will tell you what your options are. We could have left 100amp service if HWPC was set at lower setting, but I wanted max power
Yes, that what I mean. Stove , AC and dryer , if you have two, you certainly need a 200 amp service to install ev charger. The inspector will not consider you not use all the device at once. They only calculate the maximum usage to be safe. To help with the calculations, stove normally counts 40 amp , Ac counts 30 - 40 amp, dryer counts 30 amp. EV charger minimum counts 30 amp.
That’s incorrect info. Basically just wrong. Read the thread.
Are you aware that your CB’s can add up to well over double your service amps?
A 100 amp service can easily have well over 200 amps worth of CB’s.
Many 100 amp services with electrical appliances can still support a car charger.
Wherever you got ‘more than 2 electrical appliances requires 200 amp service for a car charger’ is wrong. Every case is different and requires a load calculation.
My info is wrong? Please do not w pass wrong info by saying other ppl’s comments are wrong while himself never installed EV chargers.
Let me know if anyone have AC Stove Dryer (at least two of them) and try to install EV charger and get certificate.
My comments are based on my real experience by installing the EV charger and get the certificate. I have told it is impossible by multiple electricians (to compare the price, I at least talked to 5 different electricians) while I install my EV charger for my Nissan Leaf. And also while inspector came to my house, I double confirmed that 200Amp is needed.
just realized this myself... so I'm getting quotes on an upgrade to 200a.Fcxk that’s going to be expensive supporting a mid level car. Very sad.
If I go to a 200a service - I'll definitely have more overhead - so could I install a larger breaker and increase the setting on the Tesla Wall Charger ?
