For me, it happens when I finish charging with the J1772 adapter.
I tell it to unlock the charging port so I can remove the whole thing, cable and adapter, and it locks right back. Barely gives me a chance to unplug. It should remain unlocked for more than 1 second.
If I remove the cable first without removing the J1772 adaptor, the charging door tries to close on its own and then won’t let me remove the adapter. So it’s stuck and the door will not return on its own to the open position. The car thinks the door is closed, but the J1772 adapter is still stuck in the charging port. So I have to tell it to open the charging door multiple times. It won’t do it on first try. Once it opens, I have to quickly remove the adapter or else it will try close again.
If it can’t close the door because something is in the way, it should automatically open the door again. I’m afraid the charging door mechanism can get damaged by this. But the car is not smart enough to detect this problem.
